Router 1721 not saving Config
cm
Hi Guys a quick one, I have a problem with my router which is not saving configuration after I switch off. Where do I go ? Any clues
5 Replies 5
Reza Sharifi
Chris,
Can you post sh ver?
Reza
The most common reason for a router not saving its config is that its config register has been set to ignore the startup config (typically a setting of 0x2142). The best way to check the setting is through the show version. If the config register is set to 0x2142, then use the config command config-register 0x2102 to fix it.
Rick
Rick
hi,
use erase nvram command and save it again
Kandasamy
My Prep for CCNA is going well after running the configs. Thank you @Richard Burts
You are welcome.
Rick
