VRRP issue
Salman-Abbasi
Facing issue with VRRP, when upstream router5 initiate traffic for downstream router6 then return traffic is not following VRRP VIP as Gateway. In my case switch2 is master and switch3 is standby.
If Router6 initiate the traffic then VRRP working fine.
13 Replies 13
M02@rt37
Hello @Salman-Abbasi
Do you check the MAC address table on the switches to confirm that the MAC address associated with the VRRP VIP is properly learned and forwarded to the appropriate switch port ?
Best regards
Hello M02@rt37
VIP vmac address is learned by swithc1 on port Gi0/2 which is connected master.
Best Regards
This normal
You need to add l3 link between two vrrp l3SW and use this link to config static route for any subnet behind R5 and R6 (one static route in each vrrp l3SW)
MHM
Why i need L3 link between two VRRP switches as I already configured L3 interfaces between both VRRP switches. And Upsteam and downstream both Routers are directly connectly with Switch3 then why need static route.
When Router6 reply back to Router5 then router6 use VIP as a gateway and it will be dropped at Master switch (Switch1). This is not happening in my case.
Salman
987187874
Add l3 link
And it not necessary static route it can be ospf or eigrp run in all routers and vrrp l3sw.
Do that and check again
MHM
See when Router5 initiate traffic then traffic reached at Router6 and at the time of return traffic it will do to VRRP master switch (Switch2) but this is not happening.
My only question why at the time of return traffic router6 not going towards VIP as a gateway. Even on switch1 VMAC is getting from master switch (swicth2).
For routing protocol i understand the switch2 should be routes towards router5.
Salman
+919871873874
Let me see
Show vrrp
Show mac in SW
MHM
Hello MHM Cisco World,
check the attached logs
Disable icmp redirect in l3SW2'
And check' it must know return use l3SW2 butnif this SW dont have route to Router then the ping is drop
MHM
Still having issue
In vios6
Did you disable ip routing
And config
Ip defualt gw point to VIP or VRRP
MHM
Issue resolved thanks for your support.
Disabled the IP ICMP redirect on Router6 then return traffic is going via VIP .
You are so so welcome
MHM
