02-07-2011 02:07 PM - edited 03-04-2019 11:20 AM
i must config a G/shdsl of Telecom Italia with 4 wire. Does anyone have a working config example?
Thank you.
Giuseppe
02-11-2011 12:18 PM
Documents:http://www.cisco.com/en/US/docs/routers/access/interfaces/software/feature/guide/shdslfm.html#wp1113001https://www.cisco.com/en/US/products/hw/modules/ps2641/products_installation_and_configuration_guides_list.html
Here is the configuration on the CE side:
controller DSL 0 mode atm line-term cpe line-mode 4-wire standard dsl-mode shdsl symmetric annex B line-rate 4096!
Which would map to:!
controller SHDSL 0/0/0
termination cpe
dsl-group 0 pairs 0, 1
shdsl 4-wire mode enhanced
shdsl rate auto
!check with your ISp provider and make sure that the DSLAM they have islisted in Table 4 listed in the below URL.
http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/product_data_sheet0900aecd80581fa0.html
also check wiring issue is setup correctly your Y cable is setup correctly (as per the end of this document:http://www.cisco.com/en/US/prod/collateral/modules/ps5949/ps7175/prod_qas0900aecd80591ff1.html
Log in to Community
