Router 1841 don´t charge
PEDRO AGUILAR
I have a problem with a router 1841 because a student erase the cisco ios, but, don´t charge the rommon, only see symbols when i use the console cable,
thanks for your help.
i see this simbols: router error.JPG
riadh1982
héllo
try changeing the baud rate in hyperterminal to different values (9600 default, try 115200)
i have faced similar problem when student put a  not-classic conf-reg,
bye
russell.turner
The settings in the Hyper Terminal need to be set correctly; otherwise, "strange-looking" or garbage characters may show up on the screen. When you set up the connection, use these settings:
Bits per sec    :  9600
Data bits       :     8
Parity          :  none
Stop bits       :     1
Flow control    :  none
riadh1982
héllo
bye
Right-o.  Go back into ROMmon (by removing the CF and booting the router without the CF) and type the command "unset BAUD".  Make sure the "BAUD" is in all caps the "unset" is in lower caps (use Notepad).  Once this is done, reboot the router.  Make sure you give the student an "F" or something.    He he he ...
thank´s it works with a baund of 57600.
