Router 2800
suvinv2005
hai can u help me how to change the user name and password of my router 2800.I am acessing via telnet
spremkumar
Level 9
Level 9
If you are trying to recover the password of your router then you can make use of this link ...
http://www.cisco.com/en/US/products/hw/routers/ps259/products_password_recovery09186a0080094675.shtml
if you want to change the telnet(line vty) password then better way is to create additional sessions on line vty or else use password recovery and change the line vty password...
regds
follow the above method.
config t
username new password new
no username old password old
see that you are loged in with new username after you have created on and then remove the old username and password.
Hope this is helpful.
regards,
Pravin
