Router 2801 don´t connect
PEDRO AGUILAR
I have a router 2801, but i can't connect with the console cable, i prove many configurations and bits rate, but i can´t see data in the hyperterminal
thanks for your help
PEDRO AGUILAR
I have a router CISCO 2801, but i cant get connected with the console cable; i've tried many configs and bit rate, but i cant see any data in the hyperterminal
sorry for the redaction, but my english is very bad.
Things you can check:
1. Try different cable
2. Try from a different computer
3. Try using a different program such as Putty, Teraterm, SecureCRT, etc.
4. Check the lights on the 2801 to make sure it's booting fine.
Let's isolate the issue.
Federico.
Hello Pedro,
In addition to what Federico said. Is the console cable connected to your PC or laptop by regular 9 pin adaptor that comes with Cisco devices or by USB?
Reza
yes, i try with a pc using COM1, and with a laptop using a USB-serial adaptor.
