Router 2811 rommon with problem in flash
botibasimon
Hello
I have a question referent at Router 2811 i can't load the ios since flash: when this start or reload, this send a message referent to not recognize the flash: and that no contein the valid FS.
Here is the error message:
System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Initializing memory for ECC
c2811 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Upgrade ROMMON initialized
boot: cannot determine first executable file name on device "flash:"
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
please what I can to do that for solve this problem?
thanks
Mark Malone
Looks like image has been corrupted , you can try to do an xmodem/tftpdnld to get an image back on it when its in rommon
http://usnetwork.blogspot.com/2008/10/fastest-way-to-recover-or-upgrade-cisco.html
https://www.youtube.com/watch?v=zxTO5qxti-I
