06-25-2012 03:23 PM - edited 03-04-2019 04:47 PM
I would like to know how to configure a router 2900 to support connection from 2 firewall ( Active Standby connections)
How can i said the router to send the traffic to the stand by when it go down the active Firewall?
I was planning to use a Switch ( layer 2 capacity only) in the middle of the equipments( between the firewalls and the router) in order to send always the traffic for 1 physical interface from the router side , and manage to route all the internatl traffic to the virtual IP of both Firewalls.
Also i dont know yet how to configure a VPN site to site if i have that scheme and some Publics NAT ( Firewall - Switch - Router ), i was planning to configure a NAT in the Router in order to allow the VPN traffic to internal IP of the Firewall but still dont know if it will work.
Thank you for your help
06-25-2012 11:20 PM
I would use a L2 switch as you intended and for the VPN just use the router as the VPN gateway but if it is mandatory that the VPN terminates on the ASA then you'll have to do VPN Passthrough on the router.
Regards.
Alain.
06-26-2012 07:00 AM
Hello, thank you for your advice, if i put a switch in the middle, how can i enable the VPN and NAT pass through the router and end in the Firewall?
i was planning on use a nat in the router (in oder to allow the vpn site to site connection and the internal nat to the firewall) and static routes for reach my internal network.
Also do i need to setup a new isolated ip for this connection ( firewall - switch router) and put all mi private IP's in the WAN interface of the Router?
