01-14-2021 03:34 AM
Hello all.
I have an old router. After I accidentally changed a few things in Rom Moniter, I can no longer access Router via console port.
There is no error message but as the picture shows, nothing happens. I have tried everything. Can someone help me.
Solved! Go to Solution.
01-14-2021 03:37 AM
Looks for me now, its more of Baudrate issue, start from lower to 9200 to high level and see if that works.
Trun off the device and turn on post all the output - with this output we are not sure what is going on at the console.
01-14-2021 03:37 AM
01-14-2021 05:09 AM
Thank you:) The problem was with baud rate.I have changed baud rate and it works
01-14-2021 03:51 AM
can you break into ROMMON (Ctrl+Break within 10 seconds after power up) ?
That said, what is the exact router model you have (3701 - is that one of the old Cisco 3700 Series Multiservice Access Routers) ?
