Router 3745,itself breaks in many lines (have 30 modems mica-K56flex)
griger1979
Help me please
A have router 3745 with 30 modems mica-K56flex.
line 97 126
exec-timeout 0 0
no flush-at-activation
modem InOut
modem autoconfigure type mica-K56flex
transport input all
transport output all
autoselect during-login
autoselect ppp
line 129 158
exec-timeout 0 0
modem InOut
transport input all
autoselect ppp
in few days lines is break :
line 97
exec-timeout 0 0
timeout login response 0
modem InOut
data-character-bits 8
exec-character-bits 8
special-character-bits 8
length 0
width 0
no history
no editing
transport preferred none
transport input all
escape-character soft 0
escape-character 0
autoselect ppp
hold-character 0
no ip tcp input-coalesce-threshold
lat out-group all disabled
line 98
exec-timeout 0 0
modem InOut
transport input all
autoselect ppp
line 99
exec-timeout 0 0
modem InOut
length 0
width 0
no history
no editing
transport input all
escape-character 0
autoselect ppp
hold-character 0
the router itself breaks lines and save it in STARTUP configuration
Richard Burts
Gregorys
In looking at the file that you posted it looks like the router started with a standard config for all of the modem lines. And then for some reason some of the lines have had extra lines added to them. If the extra lines are causing problems then you can try to remove the extra lines and return the config to its original state. You could try this:
config t
line 97 126
no timeout login response 0
no data-character-bits 8
no exec-character-bits 8
no special-character-bits 8
no length 0
no width 0
history
editing
no transport preferred none
no escape-character soft 0
no escape-character 0
ip tcp input-coalese-threshold
no lat out-group all disabled
line 129 158
no length 0
no width 0
history
editing
Give this a try and let us know if it helps.
Rick
Rick
I do, but then is again broken
what is reason?
