Router 3825 fried console port and admin down ethernet IF
DrWily
I have a 3825 router with a dead console port. Plus, I can't access to CLI through ethernet port because they admin down after a reset. The router boot and after that, ethernet port are disabled.
How can I acces to CLI in this case ?
Thanks for your help.
7 Replies 7
Mark Elsen
  - You can't have an idea of the current functional state of the device without a working console (such as the ability to scrutinize the boot process) , so try factory reset and check if the console can become alive  ; if there is no console , then you should go for RMA.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
The boot process going well, I can see the additional cards initialising and Ethernet interface going enable and disable after boot. Installed cards works as expected (I setup these card just before console port fail) but console port stop working just before I enter no shutdown for ethernet I/F... no luck.
Is there a way to force a startup config from CF instead of nvram ? With this, I will be able to enable telnet and AUX port.
What @Mark Elsen is asking is if after factory reset of the router, do you see the boot process displaying on your terminal screen?
Should see messages like these ones:
Booted IOSv. Boot args: [/vios-adventerprisek9-m]
Smart Init is enabled
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, IOSv Software (VIOS-ADVENTERPRISEK9-M), Version 15.9(3)M6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Mon 08-Aug-22 15:22 by mcpre
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco IOSv (revision 1.0) with with 460001K/62464K bytes of memory.Installed image archive
Processor board ID 9SPOKHZUO8J62H5VGSQCE
4 Gigabit Ethernet interfaces
DRAM configuration is 72 bits wide with parity disabled.
256K bytes of non-volatile configuration memory.
2097152K bytes of ATA System CompactFlash 0 (Read/Write)
0K bytes of ATA CompactFlash 1 (Read/Write)
11217K bytes of ATA CompactFlash 2 (Read/Write)
0K bytes of ATA CompactFlash 3 (Read/Write)
Press RETURN to get started!
Regards, LG
*** Please Rate All Helpful Responses ***
DrWily
No there is no text outpout coming from console or AUX port when I power up the router. However the boot process going well, I just can't access the console or any admin interface.
                           >.... However the boot process going well
                  - How can you verify that when there is no console ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
@Mark ElsenBecause of activity of the installed cards. There is a PVDM module that initialised only after IOS load for example. PVDM LED lit after the boot process, and there, it lit orange then green when the router finish booting. Plus, there is a configured NM-8AM-V2 card who answer call (but can't routing it beacuse of admin shutdown of ethernet interfaces). It means the card has been setup and therefore that the boot process was successful.
In this case, like @Mark Elsen suggested, you should try to get an RMA on it.
Regards, LG
