Router 4331 is not working
Dear All,
I have an issue with router 4331. The router not appeared any output over CLi by SSH or console cable, and I sure the console cable is working fine
I used this cable with another device to check the cable and found everything was working fine. Plus,
The leds (Temp , Pwr , FAN and STAT ) at the router are flapping, and the flash led is not working.
How to solve it
Mark Elsen
 - Possible hardware problem, can you power cycle -> is there still any output and or boot info's presented on the console ?
 M.
I agree with @Mark Elsen, this sounds like a hardware failure. How old is the device ? I remember there to be an issue with the internal hardware clock, which would cause the device to fail. Check if the field notice below applies:
https://www.cisco.com/c/en/us/support/docs/field-notices/642/fn64253.html
