Router 819G - Сellular use wrong profile
glevatskiy
Hi all
I have a Cisco 819G Router
In the router has 2 sim cards of different providers.
Prescribe two profiles
specified in the settings of the controller:
controller Cellular 0
  gsm sim profile 2 slot 1
  gsm failovertimer 1
Default sim 0 dials using Profile 1
When activate SIM 1:
"cellular 0 gsm sim activate slot 1"
  attempts occur through dialer profile 1
Profile 2 is inactive.
What could be the problem?
If I change the settings for "profile 1", the second Sim successfully dials.
chat-script gsm "" "ATDT*99***1#" TIMEOUT 60 "CONNECT"
 gsm failovertimer 1
interface Cellular0
 mtu 1450
 ip address negotiated
 encapsulation ppp
 dialer in-band
 dialer idle-timeout 0
 dialer string gsm
 dialer-group 1
 async mode interactive
line 3
 exec-timeout 0 0
 script dialer gsm
 logging synchronous
 modem InOut
 no exec
 transport input ssh
 transport output ssh
10 Replies 10
can you share the " sh cell 0 all" output
attached output
Just noted that the  IOS in the 819 must be Mainline 15.3(3)M or later for the dual sim feature to work.
What is your version?
Also have you seen this link
http://www.cisco.com/c/en/us/td/docs/routers/access/800/819/software/configuration/Guide/819_SCG/3routconf.html#pgfId-1184491
Yes, I read it.
I updated IOS version. Now 15.3. (3) M6.
The settings for the controller:
  gsm sim profile slot 2 1
  gsm max-retry 1
  gsm failovertimer 1
If I activate a different sim, "cellular 0 gsm sim activate slot 1", it is still used 1 Profile
have you got
gsm sim profile 1 slot 0
and
on the controller cell 0
I do not quite understand the question. In the post above I wrote configuration controller Cellular 0.
  gsm max-retry 1
  gsm failovertimer 1
gsm sim profile 1 slot 0 - it was written, but not displayed
I have a similar problem with C819HG+7-K9 and CGR1120/K9.
Has anyone found a solution?
what exactly is the problem ? Dual SIM cards using the wrong profiles ?
Yes. Both SIM cards (slot 0 and slot 1) use the first profile regardless of the setting
controller Cellular 3/1
