Configuring PAT
ferdao71493
Can anybody help with given task in retake file  Part 3 about PAT??
Since there are very little instruction for this part I even don't get what is exactly wanted.
add the lines marked in bold to the configuration of your Gateway router:
Gateway#sh run
Building configuration...
Current configuration : 1605 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Gateway
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
--> ip dhcp excluded-address 192.168.1.65
--> ip dhcp excluded-address 192.168.1.129
ip dhcp pool P10
network 192.168.1.64 255.255.255.192
default-router 192.168.1.65
ip dhcp pool P20
network 192.168.1.128 255.255.255.192
default-router 192.168.1.129
no ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX15245Y7X-
spanning-tree mode pvst
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 1 native
ip address 192.168.1.1 255.255.255.252
--> ip nat inside
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip address 192.168.1.65 255.255.255.192
--> ip nat inside
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
ip address 192.168.1.129 255.255.255.192
--> ip nat inside
interface Serial0/0/0
no ip address
clock rate 2000000
shutdown
interface Serial0/0/1
ip address 209.165.201.18 255.255.255.252
--> ip nat outside
interface Vlan1
no ip address
shutdown
router eigrp 10
network 192.168.1.0
network 209.165.201.0
--> ip nat pool ISP 209.165.201.18 209.165.201.18 netmask 255.255.255.252
--> ip nat inside source list 1 pool ISP overload
or
--> ip nat inside source list 1 interface Serial0/0/1 overload
--> ip route 0.0.0.0 0.0.0.0 209.165.201.17
ip classless
ip flow-export version 9
--> access-list 1 permit 192.168.1.0 0.0.0.255
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
8 Replies 8
Hello
I have already supplied you with that in the part1-3 configuration PT attached in previous post
Kind Regards
Paul
Alright sir, I just checked it, but I can still not ping from pc's to loopback from your file neither.
at the same time can you help me understand what is exactly wanted and which commands should be used ?
Hello
Well i can so not sure what has changed on the file i orignally sent you
Kind Regards
Paul
I can see now that pings are successful but most important thing is that I don't get what is required exactly on Part 3 and how to configure that.
Gateway#sh run
version 15.1
hostname Gateway
ip dhcp pool P10
ip dhcp pool P20
no ip cef
no ipv6 cef
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
--> ip nat inside
--> ip nat inside
--> ip nat inside
no ip address
clock rate 2000000
shutdown
--> ip nat outside
interface Vlan1
no ip address
shutdown
router eigrp 10
network 192.168.1.0
or
ip classless
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
One more question:
It says: 1. Remove the private addresses (192.168.1.x) from the EIGRP configuration, to make
sure that they will not be visible to the outside network.
How did you decide to remove 192.168.1.65 and 192.168.1.129, but not 192.168.1.1 nor 192.168.1.64 and 192.168.1.128 ?
actually:
The access list 'removes' the entire 192.168.1.0/24 address space, and that includes all the addresses you mentioned...
Hello
Is this an entirely new project to the one you originally posted if it isn’t the  why do you have eigrp running when your project clearly states to use ospf
Also it doesn’t mention creating a dhcp scope or using static routing.
when it says remove the private addresses it means stop advertising them in the routing process that’s it - then to allow communication to the isp loopback you would need to implement NAT on the gateway rtr making sure is receiving a default route dynamically from the isp rtr
As I cannot open your zip file apologies if this is indeed an entirely different project
Kind Regards
Paul
