router 831 - SMS2k - ADSL Problems
simon.dever
I am installing a Cisco Ethernet Router 831 on a network to act as a gateway to the Internet. The internet is ADSL and terminates at a modem which is then connected via ethernet into the WAN link on the router (E1). There is a SMS2k server and about 15 workstations (XP/2k) on the network connected to an unmanaged 24 port switch. The switch is connected to (E0) an ethernet port on the router's built-in switch. The workstations and server can see the router but cannot see the Internet or the WAN link. Here is my configuration:
dms#sh run
Building configuration...
Current configuration : 1223 bytes
version 12.3
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname dms
enable secret 5 <omitted>
enable password 7 <omitted>
no aaa new-model
ip subnet-zero
no ip domain lookup
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address 192.168.16.10 255.255.255.0
ip nat inside
no cdp enable
hold-queue 32 in
interface Ethernet1
ip address 203.x.x.106 255.255.255.252
ip nat outside
duplex auto
no cdp enable
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
ip default-gateway 203.x.x.106
ip nat inside source static 192.168.16.2 203.x.x.106
ip classless
ip http server
no ip http secure-server
line con 0
exec-timeout 120 0
login
no modem enable
stopbits 1
line aux 0
line vty 0 4
access-class 23 in
exec-timeout 120 0
login
scheduler max-task-time 5000
end
Any help would be highly appreciated, nothing I do seems to make a difference (adding acls, deleting them, static ip routes, router rip, NAT/PAT, etc).
Thanks in advance for any and all help regarding this matter.
Simon
thisisshanky
Level 11
Level 11
In this mode, apply following commands.
Router(config)#
no ip default-gateway 203.x.x.106
no ip nat inside source static 192.168.16.2 203.x.x.106
ip route 0.0.0.0 0.0.0.0 203.x.x.Y
ip nat inside source list 1 interface e1 overload
access-list 1 permit 192.168.16.0 0.0.0.255
PS: In your configuration the E1 interface has an address 203.x.x.106, and the default-gateway command has been configured as 203.x.x.106. This is not correct. Your ISP should have given you a gateway of last resort (default gateway). Note that I have specified the command,
ip route 0.0.0.0 0.0.0.0 203.x.x.Y. YOu need to find out from your provider what the default gateway is. and replace Y with the last octet of the IP address you get from the service provider.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
So it would be wrong to use a static one to one mapping of NAT for the server?
Hey guys,
Well I made the changes i also tried both versions of:
ip route 0.0.0.0 0.0.0.0 Ethernet1
in which Y was replaced with the gateway from the ISP
in what case would I have reason to use the command:
router(config)#ip routing
At the moment the workstations and server can see the router, even
the WAN link (ethernet1) side. But can see no further toward the
Internet.
I think thats where the problem is, some misconfiguration on
ethernet1 or acl/nat/pat.
How would I go about setting up pat for services like ftp, smtp etc?
when i changed the access list to extended acls and allowed tcp and ip through from all andresses i got this:
(attachment 1)
Then when I setup the nat and did a "debug ip nat translations detail" I got a bunch of output:
(attachment 2)
And "show ip nat translations" showed:
Pro Inside global Inside local Outside local Outside global
tcp 203.x.x.106:3389 203.x.x.106:3389 211.x.x.136:4028 211.x.x.136:4028
tcp 203.x.x.106:25 203.x.x.106:25 221.x.x.143:1181 221.x.x.143:1181
Very confused,
Simon
