BGP filtering with route-maps
snofrar
I have a BGP neighbour with a route-map to filter incoming updates, this route-map only has one permit statement with a ACL match clause, but I've realized that this ACL doesn't exist.
I thought it should block everythig but I can see all the networks from this neighbour, is this a normal behaviour ?
thisisshanky
Level 11
Level 11
Yes thats correct. The ACL needs to be in place for filtering to happen.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
wkumari
Yup, this is normal behavior. All ACLs have an implicit deny at the end, but only if they exist!
This means you can do
no access-list 101
int f0/0
ip access 101 in
and nothing will happen, but as soon as you add the first line to 101 you will start denying everything (other than what you explicitly allowed in the first line.)
Warren.
Harold Ritter
If the ACL is not configured all routes are accepted indeed. Make sure you do configure an ACL.
Hope this helps,
Thank you all for the information, I thought that even the ACL doesn't exist there was an implicit deny.
The configuration is being arranged and all is in place, thank you
