Router ASR1002 IOS code upgrade
gscalia01
all,
I'm planning of doing a IOS upgrade to an ASR1002 router from current version Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.0(1)S, to a newer code asr1000rp1-adventerprisek9.03.04.04.S.151-3.S4.
Any suggestions or step by steps documentation i can get my hands on?
Jack.
6 Replies 6
Leo Laohoo
Copy the IOS to the boot flash of your router.
Change the boot variable string.
Reload the router.
Don't forgot to upgrade the bootstrap too.
Leo,
Thanks for the feedback and I do appreciate it.
I did a sh ver of one of the device to be upgraded (see below) now when you say to upgrade the bootstrap as well are youi referring to  Rommom ?
Our release management is recommending to upgrade to version  15.1(2)S1-3.2.2S having say can i just upgrade the IOS or do i still need to upgrade the bootstrap as mentioned?
Jack
sh ver
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.0(1)S, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Jul-10 21:34 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2010 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
nyc_wfcinetrt1a uptime is 2 years, 27 weeks, 18 hours, 41 minutes
Uptime for this control processor is 2 years, 27 weeks, 18 hours, 43 minutes
System returned to ROM by reload
System image file is "bootflash:/asr1000rp1-adventerprisek9.03.01.00.S.150-1.S.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor with 1717513K/6147K bytes of memory.
9 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7798783K bytes of eUSB flash at bootflash:.
Configuration register is 0x2002
That's correct.
You can upgrade the IOS and the Bootstrap with only ONE reload.  Here's how:
1.  Copy the IOS first into the appliance;
2.  [OPTIONAL]  Change the boot variable string;
3.  Upgrade the Bootstrap using the command:   upgrade rom file all
You will be prompted with a "y/n" and when you hit "y" the Bootstrap upgrade will commence and the appliance will reboot to the new IOS you've specified.
Iulian Vaideanu
Level 4
Level 4
Since you're upgrading to 3.4, why not go for 3.4.6S instead of 3.4.4?
Lulian,
Our release management team is recommending to upgrade to version 15.1(2)S1-3.2.2S.
Do i need to upgrade my bootstrap? if so what are the steps or command line for that?
does the bootstrap upgrade requires a reboot of the router ?
does this means the router will have to be reloaded twice ? one for the bootstrap upgrade and one for the IOS upgrade.
Giacomo
ROFL!  IOS-XE version 3.2(2)S was release back in 27 April 2011!  Imagine the amount of bugs, exploits and vulnerabilities that have been discovered then.
I've posted a method (above) that will allow you to upgrade the IOS and Bootstrap with only ONE reboot.
