Router C8200L-1N-4T | Last reload reason: Critical process cmand fault
hello everyone,
I have a problem with this router, I get Last reload reason: Critical process cmand fault on rp_0_0 (rc=134)
Complete management of the equipment is lost until a physical restart is applied.
Do they know any solution to apply it.
8 Replies 8
Enes Simnica
hello @Luis Angel Melendez Fuentes The error message "Last reload reason: Critical process cmand fault on rp_0_0 (rc=134)" indicates that the router experienced a failure in a critical process (cmand), which is the Command Manager process responsible for managing and handling CLI (Command-Line Interface) commands. This process crashing can result in the loss of management access, requiring a physical restart.
-Check logs: Use show logging and show platform to find more details about the crash. use (sh logg, sh platf. sh vers)
-Software bug: It could be a known issue. Check Cisco’s Bug Search Tool for your IOS version and consider upgrading or downgrading.
-Resource usage: High CPU or memory usage could cause this. Use show processes cpu sorted and show processes memory to investigate. use (sh processes cpu sorted, sh processes memory)
-TAC support: If the issue persists, reach out to Cisco TAC for further assistance.
-Also, a software update or checking for hardware faults should help resolve the issue.
-Enes
more Cisco?!
more Gym?!
Leo Laohoo
What firmware is the router running on?
Hi @Leo Laohoo
I share firmware:
RR01-BNT-CR02462#sh platform
Chassis type: C8200L-1N-4T
Slot Type State Insert time (ago)
0 C8200L-1N-4T ok 03:34:44
0/0 2x1G-2xSFP ok 03:32:21
R0 C8200L-1N-4T ok, active 03:34:44
F0 C8200L-1N-4T ok, active 03:34:44
P0 PWR-CC1-100WAC ok 03:34:11
P2 C8200-FAN-1R ok 03:34:11
Slot CPLD Version Firmware Version
0 21070847 17.6(6r)
R0 21070847 17.6(6r)
F0 21070847 17.6(6r)
RR01-BNT-CR02462#
Post the entire output to the command "sh version".
Attached command
RR01-BNT-CR02462#SH VER
Cisco IOS XE Software, Version 17.09.03a
Cisco IOS Software [Cupertino], c8000be Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.9.3a, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2023 by Cisco Systems, Inc.
Compiled Wed 29-Mar-23 01:16 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2023 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 17.6(6r)
RR01-BNT-CR02462 uptime is 11 hours, 43 minutes
Uptime for this control processor is 11 hours, 44 minutes
System returned to ROM by Critical process cmand fault on rp_0_0 (rc=134)
System restarted at 08:22:23 CDT Mon Sep 9 2024
System image file is "bootflash:packages.conf"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Controller-managed
The current throughput level is unthrottled
Smart Licensing Status: Smart Licensing Using Policy
cisco C8200L-1N-4T (1RU) processor with 3699266K/6147K bytes of memory.
Processor board ID FJC27181R50
Router operating mode: Controller-Managed
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
7573503K bytes of flash memory at bootflash:.
RR01-BNT-CR02462#
Post the complete output to the following commands:
dir bootflash:tracelogs
dir bootflash:core
Thx @Leo Laohoo
Attached commands
@JASMIEL ROMERO wrote:
shutdown_journal_rp0_20240910052551.log
Find this file and attach it.  I want to see this.
Have a look:
Use the command:
dir bootflash:tracelogs/*.logs
And compare the date stamps of the output:
dir bootflash:core
This router has been crashing very regularly.
