router configs for AT&T AVPN services
alison.hou
We are now upgrading our service to AT&T AVPN service ( 2t1). What are configs?
thanks,
alison
John Blakley
It's a standard MPLS connection so your configs will be based on that. Do you have multiple locations? AT&T allows for you to choose your routing protocol also, so what did you choose? We're going to need a little more information.
Hth,
John
HTH, John *** Please rate all useful posts ***
We are upgrading our IPFR VPN service( with T1 access) to AVPN service ( with 2T1access)
Here are current related configs:
controller T1 0/0/0
  framing esf
  linecode b8zs
  cablelength long 0db
  channel-group 0 timeslots 1-24
controller T1 0/1/0
framing esf
linecode b8zs
interface serial0/0/0/0
no ip address
encapsulation frame-relay IETF
ip route-cache flow
tx-ring-limit 3
tx-queue-limit 3
frame-relay traffic-shaping
interface serial0/0/0:0.1 point-to-point
description  ATT IPFR to PER
bandwidth 1024
ip address 10.17.1.165.255.255.255.252
frame-relay interface-dlci 777
  class FRTS1024
router eigrp 2
network 10.0.0.0
no auto-summary
router bgp 65089
we are going to intall a new VWIC2-2MFT- T1 card for the new 2T1. what are config changes for the new AVPN service?
thanks,
Alison
Alison,
The best information that I can give you is to get the configs from ATT for your specific circuit. We utilize AVPN, but there are usernames attached to the link that they've assigned. Otherwise, if you're going to be using both T1s, make sure that you have ATT provision the circuit for a multilink connection. If not, the circuit won't come up. If you provision it with non-MLP, then you should be able to get 1 circuit running on it, but the ip address has to go on the serial interface and not the mlp interface whereas it goes on the mlp interface and utilizes both circuits if you have an mlp provisioned circuit.
ATT will definitely be able to give you configs for your circuit.
HTH,
John
