router dead process
kfirharel
we have a router cisco 3825.
the router has 256 mb of memory, but it is not using all of it because of dead process which is called "usb_startup" this dead process takes something like 60mb of the router memory. the reload command doesnt solve the problem.
how can we solve the probelm?
thank you
paolo bevilacqua
please post output of "show version" and "show process memory ", where is the PID of "usb_startup", first number on the left.
Also, do you have any error message leading you to believe the router is out of memory ?
here is the show ver
Cisco IOS Software, 3800 Software (C3825-SPSERVICESK9-M), Version 12.4(6)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 23-Feb-06 01:02 by ccai
ROM: System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
tira_barak uptime is 7 hours, 45 minutes
System returned to ROM by reload at 07:39:49 UTC Wed Apr 25 2007
System image file is "flash:c3825-spservicesk9-mz.124-6.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.1) with 227328K/34816K bytes of memory.
Processor board ID FTX1020A5L4
2 Gigabit Ethernet interfaces
1 Serial(sync/async) interface
1 ISDN Basic Rate interface
1 Channelized (E1 or T1)/PRI port
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
here is the show memory dead
66481400 0000000028 664813A4 6648144C 001 -------- -------- 60E34604 USB Startup
6648144C 0000000028 66481400 66481498 001 -------- -------- 60E34604 USB Startup
66481498 0000000072 6648144C 66481510 001 -------- -------- 60E34604 USB Startup
66481510 0000000028 66481498 6648155C 001 -------- -------- 60E34604 USB Startup
6648155C 0000000028 66481510 664815A8 001 -------- -------- 60E34604 USB Startup
664815A8 0000000132 6648155C 6648165C 001 -------- -------- 60E34604 USB Startup
6648165C 0000000052 664815A8 664816C0 001 -------- -------- 60E33654 USB Startup
Address Bytes Prev Next Ref PrevF NextF Alloc PC what
664816C0 0000000040 6648165C 66481718 001 -------- -------- 60E32F08 USB Startup
66481718 0000000028 664816C0 66481764 001 -------- -------- 60E32F90 USB Startup
66481764 0000000028 66481718 664817B0 001 -------- -------- 60E33690 USB Startup
664817B0 0000000028 66481764 664817FC 001 -------- -------- 60E328CC USB Startup
664817FC 0000000036 664817B0 66481850 001 -------- -------- 60E32F90 USB Startup
66481850 0000004404 664817FC 664829B4 001 -------- -------- 60E3290C USB Startup
664829B4 0000000040 66481850 66482A0C 001 -------- -------- 60E32F08 USB Startup
lots and lots of the message above
the "usb_startup" is only seen on the show memory dead command.
here is a capture of the show memomry, you can see that the sum of process and i/o is not even close to 256 mb.
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 65894CE0 139899680 139019004 880676 621840 681444
I/O 2DE00000 35651072 10723912 24927160 24913248 24910524
when i use the show process memory command you can see that dead process is using 60mb
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 43250752 15201800 25081704 614 91 *Init*
0 0 12148 340452 12148 0 0 *Sched*
0 0 812064 939656 668216 12 12 *Dead*
1 0 5052 0 12096 0 0 Chunk Manager
2 0 252 252 4044 0 0 Load Meter
