Router DHCP request trough router in bridge mode
LdT
Hi!
I try to make a bridge with ROUTER1 between the ISP side and a ROUTER2.
The goal is to get a dhcp address, for the ROUTER2 address, from the ISP side.
In debug mode I see the ROUTER2 make a discovery but there is no offer from the other side.
I have no physical access to the devices so I can't put a Wireshark in and see the traffic passing trough routers.
Can you help me to find why this does not work please? Thank you!
I have those 2 configurations :
ROUTER1
Current configuration : 1724 bytes
version 12.4
hostname ROUTER1
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
resource policy
ip cef
ip dhcp relay information trust-all
username xxx password xxx
bridge irb
interface FastEthernet0
no ip address
duplex auto
speed auto
bridge-group 1
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  protocol bridge broadcast
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
dsl operating-mode auto
bridge-group 1
interface Vlan1
ip address 172.x.x.x 255.x.x.x
interface Dialer0
ip address negotiated
ip access-group traffic_entrant in
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname fti/f9aphrt
ppp chap password
ppp pap sent-username fti/f9aphrt password
ppp multilink
interface BVI1
no ip address
ip route 0.0.0.0 0.0.0.0 172.x.x.x
no ip http server
no ip http secure-server
access-list 101 permit udp any any eq bootpc
control-plane
bridge 1 protocol ieee
line con 0
line aux 0
line vty 0 4
login local
monitor
line vty 5 15
login local
monitor
webvpn context Default_context
ssl authenticate verify all
no inservice
end
ROUTER 2
version 12.4
hostname ROUTER2
boot-start-marker
boot-end-marker
enable secret 5
no aaa new-model
dot11 syslog
ip cef
archive
log config
  hidekeys
ip address dhcp
duplex auto
speed auto
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan2
no ip address
ip forward-protocol nd
no ip http server
control-plane
line con 0
line aux 0
line vty 0 4
login local
line vty 5 15
login local
We had to modify ATM0 configuration on ROUTER1 to make it work :
interface ATM0
no ip address
no ip route-cache
pvc 8/35
bridge-group 1
chrihussey
Just taking a guess, but try adding:
 bridge 1 route ip
Hope this helps
Thank you for the quick reply.
I tried but it did not work.
interface ATM0
no ip address
no ip route-cache
pvc 8/35
bridge-group 1
