Router Distinguisher, EIGRP with VRF
huyan
Hi everyone,
I am learning EIGRP with VRF. In a tutorial, there is this configuration. I am not sure I understand it correctly, I put a comment  next to each command, could you helpverify them and answer the questions?
ip vrf TEST(create an instance of VRF named TEST)
rd 100:1(100 is the AS, but what is '1' ? )
interface Loopback0
ip vrf forwarding TEST(put Lo0 to the VRF Test)
ip address 192.168.100.2 255.255.255.255
interface FastEthernet0/0
router eigrp 100
address-family ipv4 vrf TEST    (Set EIGRP for vrf TEST)
network 192.168.0.0 0.0.255.255  (advertise network 192.168.0.0 0.0.255.255 to all routers with VRF in AS 100)
no auto-summary
autonomous-system 100   (Why do we need to specify AS 100 again? Isn't it being under the configuration of EIGRP 100?)
exit
Thank you!
rd
(Route Distinguisher) is a value added to an IPv4 Prefix to to change them into globally unique VPN-IPv4 prefixes.
An
RD
is either:
       - ASN-related--Composed of an autonomous system number and an
arbitrary number
 In your case 100:1 where 100 is AS number and 1 is an
arbitrary number
       - IP-address-related--Composed of an IP address and an
arbitrary number
autonomous-system
in address-family is used to configure the autonomous-system number for an EIGRP routing process to run within a VRF instance. In your case, the autonomous-system associated with the
router eigrp 100
is for the general routing table; it is not for the VRF. You can also do
address-family ipv4 vrf TEST autonomous-system 100
in recent versions:
router eigrp 100
  network 192.168.0.0 0.0.255.255   ! Enable EIGRP on all interfaces within the VRF whose ip address is in 192.168.0.0/16
  no auto-summary
exit
HTH,
Meheretab
HTH,
Meheretab
rd
An
RD
is either:
arbitrary number
arbitrary number
arbitrary number
autonomous-system
router eigrp 100
in recent versions:
router eigrp 100
  no auto-summary
exit
HTH,
Meheretab
HTH,
Meheretab
Hi Meheretab,
I really appreciate your help, your explanation have cleared out my confusion regarding configuration of EIGRP with VRF.
Thank you!
Best,
Huy.
