05-29-2014 10:41 AM - edited 03-04-2019 11:03 PM
I need to order a small router, 2911, that will access a DSL. What interfaces do I need? Can ADSL use a standard ethernet port?
Solved! Go to Solution.
05-29-2014 04:14 PM
Depends. If you have a DSL modem that's facing the ISP, then you can. You can enable the modem for "pass through" and let the router all the authentication stuff.
If you want a direct line into the router, then you'll need EHWIC-VA-DSL module.
05-29-2014 04:14 PM
05-30-2014 06:02 PM
Thanks for taking the time to rate our posts, Jimmy. ![]()
