router error 7609
csc010854800
Can anybody help me out , i am getting these
error messages continously in the router 7609 .
SLOT 1: Feb 18 06:34:52.047: %SPA_CHOC_DSX-3-SPA_CMD_SEND_ERR: Failed to send ipc_send_rpc_blocked (timeout) command to SPA
-Traceback= 407BD130 407BF6B8 407C1444 407C18DC 401FB5D4 401FB5C0
Feb 18 06:34:59.819: %CWAN_RP-4-IFCFG_CMD_TIMEOUT: Interface configuration command (0x210) to slot 1/0 timed out
Feb 18 06:34:59.819: %SPA_CHOC_DSX-3-VCCFG_ERROR: Interface Serial1/0/0.1/1/5/3:17 config command error (cmd 1, arg 4, retval 3)
-Traceback= 422C8540 422C1ED0 422E1C78 422E4524 42321A2C 413BA550 405BB2B8 413A9938 413A9924
Feb 18 06:35:09.832: %CWAN_RP-4-IFCFG_CMD_TIMEOUT: Interface configuration command (0x210) to slot 1/0 timed out
Feb 18 06:35:09.832: %SPA_CHOC_DSX-3-VCCFG_ERROR: Interface Serial1/0/0.1/1/5/3:19 config command error (cmd 1, arg 4, retval 3)
vmiller
Level 7
Level 7
Looks like an internal software error I'd get a tac case open
%CWAN_RP-4-IFCFG_CMD_TIMEOUT : Interface configuration command (0x%x) to slot %u/%u timed out
Explanation   The RP sent an configuration command to the slot specified in the error message and received no confirmation for the command.
Recommended Action   Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at
http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at
http://tools.cisco.com/ServiceRequestTool/create/http://tools.cisco.com/ServiceRequestTool/create/, or contact your Cisco technical support representative and provide the representative with the gathered information.
Explanation    A command sent from the system to a linecard has failed. This is an internal software error.
Recommended Action    Decode the traceback and get the output of the show logging command on RP and SIP and check if there are any errors being reported. Try to recreate the problem to see if there is a consistent method to recreate. Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs
