router failed to boot
amays3
the router fails to boot, it start and give me the below exceotion message with no code. is this a software or hardware failure?
it stops/fails before you can break and change the config!
System Bootstrap, Version 11.0(10c), SOFTWARE
Copyright (c) 1986-1996 by cisco Systems
Exception:
paolo bevilacqua
Is that an old 2500?
Perhaps it was sitting there because faulty..
The only thing you can try, remote the ram and check if it goes any better.
thank for your reply, I was leaning to a hardware problem but I was not sure so I'll crack it open and get to work. thanks
