3750 switch
Eduardo AYALA
The IOS is gone, command is on the "switch" mode. How do get it back up and running with a new IOS? Thanks.
5 Replies 5
Edison Ortiz
Hint:
If you do need to xmodem an image, many of the newer console ports can go much faster than the usual 9600. Very worthwhile to increase console port speed (often will still be painfully slow compared Ethernet).
How do you do that? Thanks Joseph.
Follow the procedure in this link http://www.cisco.com/warp/public/130/xmodem_generic.html
..the procedure in the link is generic for XMODEM, so ignore those router model mentioned in the link.
Dandy
you can also use tftpdnld command in ROMMON mode
