Router FastEthernet0/1 is up, line protocol is down (disabled)
tecnatan2
MrOrister
Hello!
Some outputs would help to investigate the problem more deeply, but as a good 1st step I recommend checking the speed/duplex settings on both end to match and pay high attention for the duplex settings to be Full on both ends.
Hope I could help!
Hello @tecnatan2 ,
also make sure the port to which the router is connected in not shutdown.
Regards, LG
*** Please Rate All Helpful Responses ***
balaji.bandi
is this virtual or Physical, what devices are they ?
this could be :
1. Cable issue
2. speed Mismatch
3. duplex issue.
BB
Blue_Bird
Hello tecnatan2 ,
Cisco ethernet interfaces are normally down / down if they don't have a link. If you're seeing up / down, the most likely causes are:
Cable fault
Speed/duplex mismatch
Cable is good..., if that is connected between two switches or between switch and router. but one side switch/router had it's interface in "administratively down" state, will cause the issue. "no shutdown" command at interface level solve's the problem..!!
Best regards
******* If This Helps, Please Rate *******
