04-07-2008 11:25 PM - edited 03-03-2019 09:27 PM
Will a 2821 be enough for a gigabit link with projected load of 100Mbps?
Solved! Go to Solution.
04-08-2008 04:16 AM
I've attached a router performance chart that's commonly used on these forums. In the bandwidth column for a 2821 you'll see it rated at 87 Mbps. This for 64 bytes sizes packets; worst case. Throughput often increases with increased packet sizes, and "normal" packet sizes usually average bigger, but other router services will reduce throughput. Also, you don't really want to run a router at 100% CPU, should have a fair size CPU cushion (about at least a third).
The 2851 might be sufficient, with its rating of 112 Mbps, if the 100 Mbps is the total aggregate bandwidth usage. If you're thinking 100 Mbps duplex, i.e. 200 Mbps aggregate, then you likely will want to move up to the 38xx series.
PS:
If the router isn't needed for WAN features, but only for pure LAN routing, you might consider using L3 switches such as the 3560 or 3750 series.
04-08-2008 01:36 AM
No. You should look at a 3825 or 3845.
04-09-2008 02:10 AM
Hi, to the person that has low rated my post above, please think better and be fair next time, because my recommendation is 100% true and correct like Joseph has explained in more detail.
To reiterate, if you use a 2821 to handle 200 mbps traffic on a sustained basis, and it will melt.
04-08-2008 04:16 AM
PS:
04-08-2008 07:17 PM
We're looking at close to 200 aggregate and will be having a backup link for the main link.
Thanks for the response. All helpful.
