Router for Channelized DS3.
mark.jenks
Right now, I have 2 3662's with channelized T1 cards in them, running about 22 half T1's to the branch offices. I'm looking for a replacement router that can do Channelized DS3, to grow these offices to full T1's. I was looking at the 2851, but should I be looking higher at the 7300's?
Giuseppe Larosa
Hello Mark,
I don't see a channelized DS3 module not even for C3845
see
http://www.cisco.com/en/US/prod/collateral/routers/ps5855/product_data_sheet0900aecd8016a8e8.html
I would go for a C7204VXR that can install channelized Ds3 port-adapter
Use the following as a reference
http://www.cisco.com/en/US/docs/interfaces_modules/port_adapters/install_upgrade/multichannel_serial/channelized-t3_dual-wide_install_config/4584ct3d.html
Hope to help
Giuseppe
I thought the 7200 was EOL soon?
What about the 7304?
Hello Mark,
I think it is EOL a 7206VXR with NPE 400 or less processor engine.
There are NPE-G1 and NPE-G2 processor engines and they are used, we have just bought two.
See
http://www.cisco.com/en/US/prod/collateral/routers/ps341/prod_end-of-life_notice0900aecd806b8c96.html
C7304 can be OK I haven't used it but I think it shares the PAs with 7200 so can be fine
Hope to help
Giuseppe
