Router for dial up access
net buzz
Hi!
I am designing a solution whereby remote users will need to access the central server using analog lines.
I have chosen the Cisco 2811-SEC/K9 router, HWIC-1CE1T1-PRI card and the PVDM2-36DM modem module.
The main site will be equipped with an ISDN PRI line having 30 channels.
The 30 remote users will each be equipped with a modem enabled PC and will be having an analog telephone line.
The remote users will need to dial up using the ISDN line number and the secure the connection using a defined username and password.
Is there any additional hardware required for the setup to work properly.See attached document.
Alvin
Shelley Bhalla
Level 3
Level 3
As far as Hardware goes this is enough to do what you are doing.I have seen this hardware used for dial-up in the past many times.
Shelley Bhalla
CCIE #20002
Cisco TAC - Carrier Services
Shelley Bhalla
Level 3
Level 3
Shelley Bhalla
CCIE #20002
