01-16-2025 11:55 AM - edited 01-16-2025 11:57 AM
Hello!
I have a C1111-8P router. Unfortunately I can't update the IOS image. For the time being I have temporarily set gi0/0/1 as a DHCP client. Then I downloaded the IOS image from my TFTP server and calculated the MD5 sum.
Directory of bootflash:/
11 drwx 16384 Apr 14 2021 08:13:07 +00:00 lost+found
163201 drwx 4096 Jan 16 2025 17:57:21 +00:00 .prst_sync
12 -rw- 457963732 Apr 14 2021 08:21:21 +00:00 c1100-universalk9_ias_npe.16.09.05.SPA.bin
114241 drwx 4096 Jan 16 2025 17:56:07 +00:00 .installer
89761 drwx 4096 Apr 14 2021 08:27:24 +00:00 core
65281 drwx 4096 Apr 14 2021 08:26:02 +00:00 .rollback_timer
73441 drwx 4096 Apr 14 2021 08:26:03 +00:00 gs_script
106081 drwx 73728 Jan 16 2025 18:41:25 +00:00 tracelogs
122401 drwx 4096 Jul 10 2021 13:27:30 +00:00 .dbpersist
24481 -rw- 30 Jan 16 2025 17:57:21 +00:00 throughput_monitor_params
81601 drwx 4096 Apr 14 2021 08:27:02 +00:00 onep
24482 -rw- 35 Jan 16 2025 12:44:44 +00:00 pnp-tech-time
24483 -rw- 66041 Jan 16 2025 12:44:54 +00:00 pnp-tech-discovery-summary
24484 -rw- 10220 Jan 16 2025 17:57:31 +00:00 vlan.dat
24485 -rw- 567 Jul 11 2021 06:26:35 +00:00 1625984510647sh_tech.txt
24486 -rw- 567 Jul 11 2021 06:27:22 +00:00 1625984554263sh_tech.txt
24487 -rw- 701111540 Jan 16 2025 18:34:27 +00:00 c1100-universalk9.17.12.04a.SPA.bin
130561 drwx 4096 Jan 16 2025 14:50:11 +00:00 SHARED-IOX
24488 -rwx 0 Jan 16 2025 14:50:11 +00:00 mode_event_log
138721 drwx 4096 Jan 16 2025 14:50:11 +00:00 pcap
2908606464 bytes total (1578356736 bytes free)
Configuration:
Router(config)#boot system flash c1100-universalk9.17.12.04a.SPA.bin
Router#show bootvar
BOOT variable = c1100-universalk9_ias_npe.16.09.05.SPA.bin,1;c1100-universalk9.17.12.04a.SPA.bin,1;
Router(config)#no boot system flash c1100-universalk9_ias_npe.16.09.05.SPA.bin
Router#show bootvar
BOOT variable = c1100-universalk9.17.12.04a.SPA.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
Router(config)#do wr
Building configuration...
[OK]
Router(config)#
*Jan 16 18:50:31.493: %SYS-2-PRIVCFG_ENCRYPT: Successfully encrypted private config file
Router(config)#reload
Reload:
System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
Copyright (c) 1994-2018 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
C1111-8P platform with 4194304 Kbytes of main memory
Located c1100-universalk9.17.12.04a.SPA.bin
Package header rev 3 structure detected
IsoSize = 646684672
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated C8FC40FC:3F5B9694:390E1398:ACD90582:1CB4E2E6
expected C8FC40FC:3F5B9694:390E1398:ACD90582:1CB4E2E6
RSA Signed RELEASE Image Signature Verification Successful
Image validated
Router freeze for long time, and show error:
Last reset cause: Unrecoverable Error
After rollback to universalk9_ias_npe.16.09.05.SPA.bin with rommon. The router starts without any errors.
Can I ask for help in solving this problem?
Solved! Go to Solution.
01-16-2025 02:42 PM - edited 08-19-2025 09:24 PM
@robert-gorajski wrote:System Bootstrap, Version 16.9(1r), RELEASE SOFTWARE
I suspect this is the problem -- ROMMON version 16.9(1r).
This is going to be a complicated answer.
Refer to Cisco ISR1000 ROMmon Compatibility Matrix (Table 3) and it specifically states that the router needs to be on ROMMON version 17.5(1r) if upgrading to 17.5.X 17.6.X or 17.9.X.
Finally, it is not possible to perform a direct upgrade, from 16.X.X, to 17.12.X (and later) without going through an intermediate version like 17.6.X or 17.9.X. This information or fact is undocumented. The reason why is because of ROMMON version 17.5(1r), which is not a downloadable file.
ROMMON version 17.5(1r) is incorporated into 17.6.X and 17.9.X only. It is not incorporated in 17.12.X nor 17.15.X and will not be incorporated in any later versions other than 17.6.X and 17.9.X. And like before, this fact is not documented anywhere else -- Even Cisco TAC was kept in the dark by this information.
To upgrade to Cisco IOS XE Dublin 17.12.x, follow these steps:
If you are on a device that is running software version between Cisco IOS XE 16.x to Cisco IOS XE 17.4.x, upgrade to any IOS XE image between Cisco IOS XE 17.5.x to Cisco IOS XE 17.10.x.
After performing step a, upgrade to Cisco IOS XE 17.12.x.
For devices that are running on software version Cisco IOS XE 17.5.x or later, you can upgrade to Cisco IOS XE 17.12.x directly.
So here is the plan:
1. Force the router to boot 16.9.5.
2. Read this: Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
3. Upgrade the ROMMON to version 17.12(1r) but DO NOT REBOOT the router.
4. Upgrade to router firmware to either 17.6.X or 17.9.X. Reboot
5. Upgrade to router firmware to 17.12.X & reboot.
10-01-2025 09:33 AM - edited 10-01-2025 09:37 AM
Thank you for this, however not working for me at all.
I cannot find version 17.12(1r) so I tried without it
I do have 6.12 s
Do need to start with a different image? I have Fuji
sh version
Cisco IOS XE Software, Version 16.09.01
Cisco IOS Software [Fuji], ISR Software (ARMV8EB_LINUX_IOSD-UNIVERSALK9_IAS-M), Version 16.9.1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 17-Jul-18 17:13 by mcpre
Slot CPLD Version Firmware Version
0 17100501 16.12(1r)
R0 17100501 16.12(1r)
F0 17100501 16.12(1r)
I did get the GOTCHA
Copying package files
c1100-firmware_c1100_gfast.17.06.01a.SPA.pkg
c1100-firmware_c1100_shdsl.17.06.01a.SPA.pkg
c1100-firmware_c1100_vadsl.17.06.01a.SPA.pkg
c1100-firmware_p_1t.17.06.01a.SPA.pkg
c1100-mono-universalk9.17.06.01a.SPA.pkg
c1100-rpboot.17.06.01a.SPA.pkg
WARNING: A different version of provisioning file packages.conf already exists in bootflash:
WARNING: The provisioning file from the expanded bundle will be saved as
WARNING: bootflash:c1100-universalk9.17.06.01a.SPA.conf
... package files copied
SUCCESS: Finished expanding all-in-one software package.
Oct 1 15:26:41.464 %INSTALL-5-OPERATION_COMPLETED_INFO: R0/0: packtool: Completed expand package bootflash:c1100-universalk9.17.06.01a.SPA.bin
Checked bootflash: and it doesn't matchup with what you have here or I cannot see it
#dir bootflash:
11 drwx 16384 Sep 30 2025 18:24:58 +00:00 lost+found
8161 drwx 4096 Oct 1 2025 15:39:13 +00:00 .installer
32641 drwx 4096 Sep 30 2025 18:44:25 +00:00 core
163201 drwx 4096 Oct 1 2025 15:40:40 +00:00 .prst_sync
130561 drwx 4096 Sep 30 2025 18:43:03 +00:00 .rollback_timer
155041 drwx 4096 Sep 30 2025 18:43:05 +00:00 gs_script
57121 drwx 65536 Oct 1 2025 15:41:04 +00:00 tracelogs
65281 drwx 4096 Sep 30 2025 18:47:55 +00:00 .dbpersist
12 -rw- 30 Oct 1 2025 15:40:41 +00:00 throughput_monitor_params
73441 drwx 4096 Sep 30 2025 18:44:21 +00:00 onep
13 -rw- 458170120 Sep 30 2025 18:46:57 +00:00 c1100-universalk9_ias.16.09.01.SPA.bin
14 -rw- 35 Sep 30 2025 18:49:24 +00:00 pnp-tech-time
15 -rw- 57805 Sep 30 2025 18:49:26 +00:00 pnp-tech-discovery-summary
16 -rw- 8051 Sep 30 2025 22:45:23 +00:00 running-config
17 -rw- 4949 Oct 1 2025 00:31:41 +00:00 lash:c1100-universalk9_ias.16.08.01.SPA.bin
18 -rw- 4919 Oct 1 2025 14:00:16 +00:00 packages.conf
19 -rw- 705753752 Oct 1 2025 15:22:56 +00:00 c1100-universalk9.17.06.01a.SPA.bin
20 -rw- 272 Oct 1 2025 14:33:19 +00:00 mode_event_log
89763 -rw- 13579316 Oct 1 2025 15:25:26 +00:00 c1100-firmware_c1100_gfast.17.06.01a.SPA.pkg
89764 -rw- 11527220 Oct 1 2025 15:25:26 +00:00 c1100-firmware_c1100_shdsl.17.06.01a.SPA.pkg
89765 -rw- 5592116 Oct 1 2025 15:25:26 +00:00 c1100-firmware_c1100_vadsl.17.06.01a.SPA.pkg
89766 -rw- 8451116 Oct 1 2025 15:25:26 +00:00 c1100-firmware_p_1t.17.06.01a.SPA.pkg
89767 -rw- 666993728 Oct 1 2025 15:25:30 +00:00 c1100-mono-universalk9.17.06.01a.SPA.pkg
89768 -rw- 57839132 Oct 1 2025 15:26:40 +00:00 c1100-rpboot.17.06.01a.SPA.pkg
89762 -rw- 7017 Oct 1 2025 15:26:40 +00:00 c1100-universalk9.17.06.01a.SPA.conf
#sh bootvar
BOOT variable = bootflash:packages.conf,12;
CONFIG_FILE variable =
Continued to pour over instructions and looked at this as instructed.
#dir bootflash:.conf
%Error opening bootflash:/.conf (No such file or directory)Last reset cause: LocalSoft
C1111-4P platform with 4194304 Kbytes of main memory
Located packages.conf
Unsupported package header version (1634562163)
Failed to boot file bootflash:packages.conf
autoboot: boot failed, restarting...
Resetting .......
Rom image verified correctly
System Bootstrap, Version 16.12(1r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM1
Resetting .......
Resetting .......
.▒Rom image verified correctly
Last reset cause: PowerOn
I can always boot is from romon> and then set the boot to an existing bootable image.
I cannot however get past anything else
Any advise on what I am missing here would be special as I have been in a personal loop with this for a day.
Thank you again for posting some help.
Joseph
10-01-2025 10:10 AM
Well, Well,
Of course it was my mess. I saw my error after posting sorry. I didn't rename the package file and I must have looked at that thousand times. I was concentrating on the date and not the file itself.
I got it now and thank you again
01-16-2025 02:47 PM
Is there a particular reason for using IOS 17.12.4a? If there is, I would suggest upgrading first the ROMMON version to 17.5(1r) as per Cisco recommendation: https://www.cisco.com/c/en/us/td/docs/routers/access/isr1100/software/configuration/xe-17/isr1100-sw-config-xe-17/Configuring_ROMMON.html
and then try again with IOS 17.12.4a
If there isn't a good reason for IOS 17.12.4a, can you try booting the router with IOS 17.9.5e? I'm using some C1111 with this image and don't have any issues.
08-18-2025 12:45 PM - edited 08-18-2025 12:47 PM
You must update the IOS with an intermediate version so that it updates the BIOS and with this last update you will be able to update the required IOS.
08-19-2025 02:07 AM
In case of the Cisco 1100 Integrated Services Routers has published an updated ROMMON version.
This is somewhat surprising as all documentation I have seen states that starting with 17.3 the ROMMON upgrades will be part of the IOS-XE upgrade process. I can only guess that Cisco noticed that this causes a lot of problems if customers directly jump from really old 16.x versions to the latest ones.
The Software Download Center contains a new ROMMON version 17.15(1r) that can be downloaded here:
https://software.cisco.com/download/home/286315006/type/282046486/release/17.15(1r)
According to the documentation the latest ROMMON version is 17.5(1r) so the label 17.15.(1r) might just be a typo.
HTH!
08-19-2025 09:20 PM
Yes and no.
Yes, Cisco has published ROMMON version 17.15(1r) but it is not for the mainstream 1100. This ROMMON is specific only to "ISR 1100(X) 4G/6G".
