Router giving ERROR
a.shaukat
the sh log gives me certail BADSHARE errors.. can anyone help me interpert them ??
attached is the output log
ISP says the router is broke..
what caused these errors and what do they say exactly..
6 Replies 6
milan.kulik
Level 10
Level 10
what about some IOS bug?
CSCsb13455, e.g.?
The CCO error message decoder says:
1. %SYS-2-BADSHARE: Bad refcount in [chars], ptr=[hex], count=[hex]
An internal software error has occurred.
Recommended Action: If this message recurs, copy the error message exactly as it appears on the console or in the system log, contact your Cisco technical support representative, and provide the representative with the gathered information.
With several links to different IOS Release Notes.
BR,
Milan
thats what i want to find out that is this a IOS error or somthing else??
im using IOS Cisco IOS Software, 2801 Software (C2801-ADVENTERPRISEK9-M), Version 12.4(3), RELEASE SOFTWARE (fc2)
does it have any bugs in that regards??
i just did a little research for the badshare error on IOS 12.4(3) and it gave me the following
CSCei27330
Symptoms: A router that is configured for Dynamic Multipoint VPN (DMVPN) may frequently generate the following error message:
%SYS-2-BADSHARE: Bad refcount in datagram_done
Conditions: This symptom is observed on a Cisco router such as a Cisco 871 and Cisco 1800 series that function as a DMVPN spoke.
Workaround: There is no workaround.
my running config is as under..
Router#sh run
Building configuration...
Current configuration : 3375 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot system flash c2801-adventerprisek9-mz.124-3.bin
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$kjhfhshkjh354hkjh45vVjf0
enable password 7 07867867C0E1625
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
ip flow-cache timeout active 1
no ip domain lookup
ip domain name yourdomain.com
username zaid privilege 15 secret 5 $1$Yqsdfdgdgh#%#%$ghgfQ3aSe8Weau.
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp key hello address 192.168.93.254
crypto isakmp keepalive 10
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set vpntest esp-3des esp-md5-hmac
crypto map vpntest local-address Loopback0
crypto map vpntest 10 ipsec-isakmp
set peer 192.168.93.254
set transform-set vpntest
match address 102
interface Loopback0
ip address 192.168.88.252 255.255.255.255
ip route-cache flow
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 192.168.97.156 255.255.255.248
ip nbar protocol-discovery
ip route-cache flow
load-interval 30
duplex auto
speed auto
crypto map vpntest
interface FastEthernet0/1
ip address 192.168.2.254 255.255.255.0
ip route-cache flow
load-interval 30
duplex auto
speed auto
priority-group 1
interface ATM0/2/0
no ip address
ip route-cache flow
load-interval 30
no atm ilmi-keepalive
dsl operating-mode auto
pvc 0/35
pppoe-client dial-pool-number 1
interface Dialer1
ip address negotiated
ip mtu 1492
encapsulation ppp
load-interval 30
dialer pool 1
ppp pap sent-username dslbkup password 7 00675765756756E451C09
crypto map vpntest
router ospf 10
router-id 192.168.97.156
log-adjacency-changes
network 192.168.88.252 0.0.0.0 area 12
network 192.168.97.152 0.0.0.7 area 12
ip classless
ip route 0.0.0.0 0.0.0.0 222.163.88.254
ip route 0.0.0.0 0.0.0.0 Dialer1 50 name Backup
ip route 192.168.97.152 255.255.255.248 192.168.97.153
ip flow-export source FastEthernet0/1
ip flow-export version 5
ip flow-export destination 192.168.2.22 9996
ip http server
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
access-list 102 permit ip 192.168.2.0 0.0.0.255 192.168.0.0 0.0.0.255
access-list 102 permit ip 192.168.2.0 0.0.0.255 172.16.0.0 0.0.15.255
access-list 150 permit tcp 192.168.2.0 0.0.0.255 any range 0 10000
access-list 150 permit udp 192.168.2.0 0.0.0.255 any range 0 10000
access-list 150 permit icmp 192.168.2.0 0.0.0.255 any echo-reply
access-list 150 permit icmp 192.168.2.0 0.0.0.255 host 192.168.2.254
priority-list 1 protocol ip low tcp www
priority-list 1 protocol ip low tcp ftp
snmp-server community DW RW
snmp-server community public RO
snmp-server ifindex persist
or could it be this one ??
CSCeh22021
Symptoms: When you attempt to establish a PPP session over an ATM interface, the following error message is generated and the session is not established:
%SYS-2-BADSHARE: Bad refcount in datagram_done, ptr=440A7FA0, count=0"
Conditions: This symptom is observed on a Cisco MGX 8800 series RPM-XF that runs Cisco IOS Release 12.4 when PPP over ATM is configured. However, the symptom may also occur on another Cisco router (from the Cisco 2600 series through the Cisco 7300 series) that runs Release 12.4.
man this IOS has some serious issues...
lol
Atif
Since you are doing PPP over ATM and are not doing DMVPN it would seem much more likely that you are hitting the second bug. And probably it matters less which bug it is, and matters more that 12.4(3) is fairly old code at this point and has this issue as well as some other recently announced vulnerabilities. You should start planning for a code upgrade for this router.
Rick
Rick
hmm probably... what is a DMVPN Spoke anyways
we are using dynamic vpn but not at this branch end.. we have it configured at the head office end and the branches initiate the tunnel..
but my real concern is that is the ISP guy right in terms that this error is "probably" causing the timeouts in the link..
i have 2 more branches with the same router but an older IOS 12.3(14)T7 and its working like a charm.. perhaps i should change this routers IOS to those older one for now..
