Router HSRP configuration
shridhar_sdl
Can anyone let me know weather cisco 1841 router is support HSRP or not if yes then please give me example on that router.
5 Replies 5
Jon Marshall
Yes the 1841 does support HSRP. Do you have 2 1841 routers as you cannot configure HSRP with 2 interfaces on the same router.
Jon
Hi ,
Thanks!! i have two routers 1841. can you let me know one more thing Jon , i have two 1841 router but one routers serail module is spoild totally , till now can i use those routers in HSRP using FE ports.
sourabh1000_2
hi,
primary router
interface fa0/1
desc ****LAN****
ip add 192.168.1.1 255.255.255.0
standby 1 ip 192.168.1.2 (DG of PCs)
standby 1 preempt
standby 1 track 1 (if used wan interface as ethernet)
standby router
interface fa0/1
desc ****LAN*****
ip add 192.168.1.3 255.255.255.0
standby 1 preempt
standby 1 priority 95 (Default is 100 for primary router)
hope u may get idea of the config
Which version of IOS it needed and one more thing if i want to upgrade my IOS for basic functionality then what are the charges will taken by Cisco or its free.
hi,
we are using adv.ent or sp.serv IOS for our client
and charges or fees i do not have any ideas..
