Router interface does not pass traffic.
nikhil.kulkarni
Hi All,  we have a Cisco 3825 router which does not work well with a DSL  modem(ISP provided). I have configured the Gi0/0 port of the router to  plug into this DSL modem but it does not ping to the ISP gateway. If we  do a shut/no shut on the interface then it work fine for about 30 secs.  Sometimes even for 1 hr. Then the packets drop and we cannot pass any  traffic through this interface.
Now, if the ISP connection is terminated on a computer it works fine. It works fine without dropping any packet.
I  have tried various options like using a straight/cross cable. I have  tried to configure the interface negotiation for 100/full, 100/half,  auto/auto and almost all the options.
I have also tried to interconnect the devices using a L2 device like a HUB. Nothing works.
Any recomendation on this? Has anyone seen this kind of a behavior?
Nikhil Kulkarni.
5 Replies 5
kumarpmt83
can u check with the another Gi port if its working or not.
I have done that, checked even with a different router, switch, fast ethernet and Gi eth interfaces. It does not work.
With a PC it works. !!! this looks like there is some compatibility issues between the ISP modem and Cisco devices.
Nik
Hi Nikhil ...what is the IOS?
c3825-advipservicesk9-mz.124-15.T6.bin
here goes the full sh ver:
rtr-vpn-kor-seo#sh ver
Cisco IOS Software, 3800 Software (C3825-ADVIPSERVICESK9-M), Version 12.4(15)T6,
RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 07-Jul-08 13:37 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
rtr-vpn-kor-seo uptime is 1 hour, 48 minutes
System image file is "flash:c3825-advipservicesk9-mz.124-15.T6.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 3825 (revision 1.1) with 223232K/38912K bytes of memory.
Processor board ID FTX1101A1RL
2 FastEthernet interfaces
2 Gigabit Ethernet interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
1 cisco content engine(s)
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
rtr-vpn-kor-seo#
show run int gig0/0
show int gig0/0
show run | in ip route
and what the settings we have on modem side for speed?hardcode or nego..?
