Router interface problem
network_guy11
i have cisco 2600 router connected to Pix firewall the router serial interface is connected to Internet and fastethernet 0/0 is connected to my Pix firewall i have a pulic server hosted in DMZ and my Internal lan connected to Pix accessing Internet .everythin is working fine but once or twice in a day my internal network is not able to access internet and i have to do shut and no shut on my fastethernet 0/0 then everythin works normally i feel the fast interface of router sort of hangs but when i give the show interface command it gives "FastEthernet0/0 is up, line protocol is up" but unless n until i do shut and no shut nothing works Pls advice what could be the problem Thanks
singh.ashish
U need to cek ur fast entehrnet, is any CRC errors ,input errors watever comming?
Cek same for serial interface also.Might be ur serial link get full utilize.
dear ashish
Thanks for the help i am getting 8 input errors the output of sh int fe 0/1 is attached herewith and i am using ipunnumbered fe 0/0 on my serial interface i have a 2 mpbs link which isnt fully utilised .
pls advice
thanks
the attachement
