Router interfaces 'no shut' but still down
ciaranmurphy1
Hi Guys,
this will hopefully be a quick and easy question for you guys to solve. I have a router that I have to put a very basic configuration on just so out ISP can remotely log into it and begin their more detail configuration. I have configured it and configured a 'no shut' on the interfaces.
when I connect the interfaces with the other gateway router on site the interfaces stay 'down, down' and will not come up. I have connected my laptop into the other gateway router on site with the same IP info as my preconfigured router and the interface works fine. but I cannot understand why the router interfaces won't come up.
I normally configure Switches & AP's which I'm more familiar with but I have completed the initial configuration for these routers in the past without this issue so I'm at a loss
see example config below
no service pad
hostname Router1
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 4 zDCmSTJSz2lsnvodsfvh0sd9vhjwpe980idjf
no aaa new-model
ip domain name global.alltfs.com
ip cef
no ipv6 cef
license udi pid CISCO2921/K9 sn FCZ16AF675
username USER privilege 15 secret 4 .DFNF.DFO8098DJZFB;LOZ8FBPZDF
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 115.112.187.186 255.255.255.248
no shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.10.1 255.255.255.0
no shutdown
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
no shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
ip http access-class 23
ip http authentication local
no ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 115.112.187.185
IHello
router to router connection you will require cross-over cable to establish physical connection
res
paul
Kind Regards
Paul
Hi Paul,
thanks for your reply. it turns out the router was faulty. I managed to get the interfaces up and running but on speed 10, duplex full however it was very unstable and a 'no shut' would take varying times to actually bring the interface back up, aywhere from 1 -10 minutes.
I swapped the router out with another which fixed the issue.
Thanks for posting back to the forum to let us know that the real issue was a faulty router. Based on the limited initial description of the symptoms I would certainly agree with Paul that the most likely issue was cable - straight through or cross over. But your post may serve as a reminder to readers of the forum that sometimes things that initially look like one problem may turn out to be a different problem when you dig into them more deeply.
Rick
Rick
