Router is not booting up
udayashankarsg
HI, i have 7206 router and 2 IOS has been downloaded in disk0. The IOS's are 12.2 and 12.3 but it was using 12.2 IOS.When i tried to boot the 12.3 IOS using boot system disk0:filename and i restarted the router but now the router is not coming up. Can anyone help on this
11 Replies 11
ankbhasi
Hi Uday,
Check and confirm 12.3 image exist on your disk0 and then compare the original size of the image with the size of image on your disk0.
Also check the boot path which you have specified exactly matches the image which you have on disk0 with .bin extension.
Ankur
Right now, i'm not able to get into the router. It's not booting up. Only i can get into rom monitor mode. Is there any option to log into the router.
uday
It might help us to understand the problem better if you would post the messages generated by the router when it attempts to boot.
If you are in rom monitor there are commands you can use to tell the router what image file to use and to boot the router. If the router is not booting successfully using the 12.3 image it might be good to go back to the 12.2 image till you get the problem resolved.
When you configured the boot system command to boot the 12.3 image did you also configure a boot system command to boot the 12.2 as a backup?
Rick
Rick
This is message i'm receiving when i reboot and then stops there and nothing is coming but when i press ctrl+break i can get into rom monitor mode. So is it possible to boot 12.2 IOS in rom monitor mode. Pls help me
System Bootstrap, Version 12.1(20000710:044039) [nlaw-121E_npeb 117], DEVELOPMENT SOFTWARE
Copyright (c) 1994-2000 by cisco Systems, Inc.
C7200 platform with 524288 Kbytes of main memory
I didn't configure the backup IOS to boot. Can u send the commands to mention the IOS to boot in rom monitor mode and also the commands for configuring the backup IOS.
check if dir disk0: command is available or not. if it displays both IOS there, maybe you can enter "boot " and see if it works or not.
No,i'm getting only boot option.Is there any other way of troubleshooting.
Try this in ROMMON mode.
rommon 1 > confreg
Confiuration Summary
enabled are:
load rom after netboot fails
console baud: 9600
boot: the ROM Monitor
do you wish to change the configuration y/n [n]: y
enable "diagnostic mode"? y/n [n]: n
enable "use net in IP bcast address"? y/n [n]: n
disable "use rom after netboot fails"? y/n [n]: n
enable "use all zero broadcast"? y/n [n]: n
enable "break/abort has effect"? y/n [n]: n
enable "ignore system config info"? y/n [n]: n
change console baud rate? y/n [n]: n
change the boot characteristics? y/n [n]:y
enter to boot:
0 = ROM Monitor
1 = the boot helper image
2 - 15 = boot system
[0]: 2
Configuration Summary:
enabled are:
console baud: 9600
boot: image sepcified by the boot system commands or default to: cisco2-c7200
do you wish to change the configuration? y/n [n] n
You must reset or power cycle for new config to take effect
rommon 2 > reset
if it doesn't work, try to enter 1 or 3 or 4
in "enter to boot:" and then reset.
hope it helps ....
Now the router is booting up but i'm getting router(boot)> prompt. How can i make it noraml ?
Can anyone help on this ?
Uday
The symptoms sound like the config register may not be set correctly. Would you post the output of show version from the router? We are particularly interested in the last line which will display the value of the config register.
Rick
Rick
mbroberson1
Level 3
Level 3
Change your config-register to 0x2102
