Router L2 extension Problems
Fernando Ramiro
Anyone know how i can establish a lan extender between 2 routers conected wit subinterface on wan port in encapsulation dot1q. I need to host connected in R1 ping host connected in R2 but in same network.
20 Replies 20
 But you use connection between router with dot1q on vlan 20!?
Can you send your lab confs!?
can you send configurations!?
siskum
LT-3 ping LT-2LT-3 ping LT-2LT-2:10.35.10.130 fn DHCPLT-2:10.35.10.130 fn DHCP
Routers and Switches running configurations below metioned. If you requires more info how to do configuration setup of Routers and Switches please let me know.
R1 - Router running configuration
R1>enable
R1#sh run
hostname R1
ip dhcp pool net10
network 10.35.10.0 255.255.255.128
default-router 10.35.10.1
ip dhcp pool net20
network 10.35.20.0 255.255.255.128
default-router 10.35.20.1
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.35.10.1 255.255.255.128
interface GigabitEthernet0/0.20
encapsulation dot1Q 20
ip address 10.35.20.1 255.255.255.128
interface GigabitEthernet0/1
ip address 10.35.1.1 255.255.255.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
ip default-gateway 10.35.1.1
ip classless
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/1
ip route 0.0.0.0 0.0.0.0 10.35.1.2
end
R1#
R2 - Router running configuration
R2>enable
R2#sh run
hostname R2
ip dhcp pool net10
network 10.35.10.128 255.255.255.128
default-router 10.35.10.129
ip dhcp pool net20
network 10.35.20.128 255.255.255.128
default-router 10.35.20.129
ip address 10.35.1.2 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.10
ip address 10.35.10.129 255.255.255.128
interface GigabitEthernet0/1.20
ip address 10.35.20.129 255.255.255.128
interface Vlan1
no ip address
shutdown
ip default-gateway 10.35.1.2
ip classless
ip route 0.0.0.0 0.0.0.0 10.35.1.1
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0
ip flow-export version 9
end
R2#
SW1 - Switch running configuration
SW1>enable
SW1#sh run
hostname SW1
interface FastEthernet0/1
switchport access vlan 10
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/22
switchport access vlan 20
interface FastEthernet0/23
interface FastEthernet0/24
switchport trunk allowed vlan 10,20
switchport mode trunk
interface GigabitEthernet0/2
interface Vlan1
no ip address
shutdown
end
SW1#
SW2 - Switch running configuration
SW2>enable
SW2#sh run
hostname SW2
interface Vlan1
no ip address
end
SW2#
Sisira
 Xconnect is not support for SVI in etherSwitch.
""L2TPv3 xconnect is not supported on an EtherSwitch module. This limitation is also applicable to switch virtual interfaces (SVI) that are physically terminated on an EtherSwitch module interface.""
according to this doc.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/wan_lserv/configuration/15-mt/wan-lserv-15-mt-book/wan-l2-tun-pro-v3.html
i made this:
on r1 i have one FW 10.75.76.254 connect in 1 port, vlan1 10.75.76.253 and i can ping 10.75.76.254 in r1 router, but i cant ping 10.75.76.254 in second router, i have vlan 1 10.75.76.252 and one host 10.75.76.251. I can ping 10.75.76.253 on host 10.75.76.251, but i have miss GW on FW interface, but if i configure i have no internet access. Have anyway with routes to second router ping FW 10.75.76.254!?
