Router module hanged problem
vijendra
my router module hanged in night through which isp connectivity  available due  to of hwic-2fe module goes down. how i can resolve this problem.
LJ Gabrillo
Level 5
Level 5
FastEthernet0/2/0 is administratively down, line protocol is down
     7413439 packets output, 4142244523 bytes, 0 underruns
     210455 output errors, 247846 collisions, 1 interface resets
Look at that error:
Check:
1. Physical Cable
2. Speed
3. Duplex
Leo Laohoo
GigabitEthernet0/2 is up, line protocol is up
  Hardware is PQ3_TSEC, address is c464.139b.3002 (bia c464.139b.3002)
  Internet address is 10.144.15.202/30
  MTU 1500 bytes, BW 8192 Kbit/sec, DLY 100 usec,
     reliability 253/255, txload 17/255, rxload 49/255
  Half Duplex, 100Mbps, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1584000 bits/sec, 207 packets/sec
  5 minute output rate 555000 bits/sec, 185 packets/sec
     87151 packets input, 89481833 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     77346 packets output, 30858545 bytes, 0 underruns
     2387 output errors, 356 collisions, 620 interface resets
     0 unknown protocol drops
     0 babbles, 644 late collision, 1743 deferred
     0 lost carrier, 0 no carrier, 0 pause output
What is connected to G0/2?  You've got a bad cable.
Serial0/0/0:1 is up, line protocol is up
  Hardware is DSX1
  Description: SLDC-to-PNP-on-E1
  Internet address is 10.7.10.3/24
  MTU 1500 bytes, BW 512 Kbit/sec, DLY 20000 usec,
     reliability 214/255, txload 1/255, rxload 1/255
  Encapsulation PPP, LCP Open
  Open: IPCP, CDPCP, crc 16, loopback not set
  Keepalive set (10 sec)
  Last clearing of "show interface" counters 07:47:21
  5 minute input rate 1000 bits/sec, 1 packets/sec
     84615 packets input, 10296370 bytes, 0 no buffer
     3115 runts, 0 giants, 0 throttles
     7218 input errors, 7218 CRC, 0 frame, 0 overrun, 0 ignored, 1337 abort
     95542 packets output, 51279812 bytes, 0 underruns
     0 output errors, 0 collisions, 242 interface resets
     3 unknown protocol drops
     1 carrier transitions
WTF.
Serial0/0/1:0 is up, line protocol is up
  Hardware is DSX1
  Description: SLDC-to-JMP-on-E1
  Internet address is 10.5.10.3/24
     reliability 246/255, txload 26/255, rxload 1/255
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 23
  5 minute input rate 2000 bits/sec, 3 packets/sec
  5 minute output rate 53000 bits/sec, 2 packets/sec
     267875 packets input, 29162625 bytes, 23 no buffer
     3308 runts, 0 giants, 0 throttles
     7413 input errors, 7411 CRC, 0 frame, 0 overrun, 0 ignored, 685 abort
     320838 packets output, 333693996 bytes, 0 underruns
WTF.
I have TWO questions for you:
1.  Where did you source your cables from, some hack from e-Bay?
2.  Do you actually have a network engineer?  A credible network engineer?
The line errors that we've highlighted, that is Networking 101.  If no one from your organization saw it then you've got trouble.
