Router not using all available bandwidth?
iggiggitoo
I am having trouble with a T1 connection between a cisco 7200VXR and cisco 2600. I have no problem connecting across it, but when I run a download across the link I get a flat 6KB/s. I can't seem to find what is wrong in my configuration that would be causing this.
7200 Router:
#show running
Building configuration...
Current configuration : 2262 bytes
version 12.4
hostname RTR1
boot-start-marker
boot system flash disk0:c7200-a3jk9s-mz.124-25.bin
boot-end-marker
enable secret 5 ...
aaa new-model
aaa session-id common
ip cef
ip domain name RTR1
username root password 0 abcd
controller T1 1/0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
description T1 connection
controller T1 1/1
framing esf
linecode b8zs
controller T1 1/2
framing esf
linecode b8zs
controller T1 1/3
framing esf
linecode b8zs
controller T1 1/4
framing esf
linecode b8zs
controller T1 1/5
framing esf
linecode b8zs
controller T1 1/6
framing esf
linecode b8zs
controller T1 1/7
framing esf
linecode b8zs
ip ssh time-out 60
ip ssh authentication-retries 2
ip ssh version 1
interface FastEthernet0/0
description uplink
ip address 1.2.3.5 255.255.255.0 secondary
ip address 1.2.3.4 255.255.255.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description uplink 2
ip address 1.2.4.5 255.255.255.0
duplex auto
speed auto
interface Serial1/0:0
description T1
ip address 10.2.1.1 255.255.255.248
ip nat inside
ip default-gateway 209.124.33.1
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 1.2.3.1
ip route 10.2.7.0 255.255.255.0 10.2.1.2
no ip http server
no ip http secure-server
ip nat inside source static 10.2.7.2 1.2.3.5
access-list 99 permit 10.2.1.0 0.0.0.255
control-plane
gatekeeper
shutdown
line con 0
transport output all
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input ssh
line vty 5 15
access-class 99 in
transport input ssh
end
Controller:
#show controller T1
T1 1/0 is up.
  Applique type is Channelized T1
  Cablelength is long gain36 0db
  Description: T1
  No alarms detected.
  alarm-trigger is not set
  Soaking time: 3, Clearance time: 10
  AIS State:Clear  LOS State:Clear  LOF State:Clear
  Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
  Data in current interval (270 seconds elapsed):
     0 Line Code Violations, 0 Path Code Violations
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
     0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
  Total Data (last 24 hours)
     0 Line Code Violations, 3 Path Code Violations,
     0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
     1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 130 Unavail Secs
Interface:
Serial1/1:0 is up, line protocol is up
  Hardware is Multichannel T1
  Description: to the Flint Farmers Market
  Internet address is 10.2.1.1/29
  MTU 1500 bytes, BW 1536 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, crc 16, Data non-inverted
  Keepalive set (10 sec)
  Last input 00:00:02, output 00:00:00, output hang never
  Last clearing of "show interface" counters 02:27:54
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/3/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1152 kilobits/sec
     6307 packets input, 512222 bytes, 0 no buffer
     Received 965 broadcasts, 1 runts, 0 giants, 0 throttles
     1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     5594 packets output, 4701504 bytes, 0 underruns
     0 unknown protocol drops
     1 carrier transitions
  no alarm present
  Timeslot(s) Used:1-24, subrate: 64Kb/s, transmit delay is 0 flags
2600 Router:
#show running
Current configuration : 839 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname RTR2
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 ...
enable password 7 ...
no aaa new-model
ip subnet-zero
ip cef
interface Ethernet0/0
description Link to Local Network
ip address 10.2.7.1 255.255.255.252
full-duplex
no cdp enable
interface Serial0/0
description Link to RTR1 Serial1/0:0
ip address 10.2.1.2 255.255.255.248
fair-queue
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 10.2.1.1
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 7 ...
login
end
Interface:
#show interfaces serial 0/0
Serial0/0 is up, line protocol is up
  Hardware is PQUICC with Fractional T1 CSU/DSU
  Description: Link to RTR1 Serial1/0:0
  Internet address is 10.2.1.2/29
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Last input 00:00:01, output 00:00:00, output hang never
     Conversations  0/5/256 (active/max active/max total)
     Available Bandwidth 1158 kilobits/sec
  5 minute input rate 1000 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     8680 packets input, 1005109 bytes, 0 no buffer
     Received 2958 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     11361 packets output, 1766828 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     DCD=up  DSR=up  DTR=up  RTS=up  CTS=up
edit- added updates interface output
9 Replies 9
Leo Laohoo
53747 input errors, 1895 CRC, 0 frame, 0 overrun, 0 ignored, 26043 abort
Maybe this is the reason?
Sometimes It takes another set of eyes to look at it, I made the mistake of reading 0 CRC on the 2600 side and didn't even pay attention to the 7200 CRC stats.
Thank you, I will have a tech look at the line and see if that is the problem.
Even after the technicians repaired the line and I am no longer seeing CRC errors on either side I am still getting poor performance (~6KB/s), any other thoughts?
If the link flat-lines at 6kbps then I'm suspecting the service provider is throttling it somewhere in their network.
Make sure you have no suspicious log entries on both routers.  Can you post the "sh proc cpu history" of both routers?
Is it slow one way or BOTH ways?
Hi Eric,
Either you can ask your SP to do an onsite throughput test or make an Iperf test yourself.
Please try download after disabling fair-quque.
interface Serial0/0
fair-queue
thanks
ajay
2600#sh proc cpu history
RTR2  09:12:54 PM Tuesday Mar 2 1993 UTC
                                     11111
100
90
80
70
60
50
40
30
20
   0....5....1....1....2....2....3....3....4....4....5....5....
             0    5    0    5    0    5    0    5    0    5
               CPU% per second (last 60 seconds)
    22111111 2 1115653                      1       11  1
100
90
80
70
60
50
40
30
20
10               ***
             0    5    0    5    0    5    0    5    0    5
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
                                         11 1   8
    611111111111111641411111111111111111115161116
100
90                                             *
80                                             *
70                                             *
60                                             *
50                                             *
40                                             *
30                                             *
20                                       * *   *
10 *              *                     ** *   *
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7.
             0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
7200:
ETS-DET-RTR1   08:08:06 AM Thursday Aug 11 2011 UTC
    999999999999999999999999999999999999999999999999999999999999
    777999999999999999999999999888887777777777766666555566666655
100 ************************************************************
90 ************************************************************
80 ************************************************************
70 ************************************************************
60 ************************************************************
50 ************************************************************
40 ************************************************************
30 ************************************************************
20 ************************************************************
10 ************************************************************
    9999999999999999999
    8999899788899999998                      1      1
100 #####*############*
90 #####*############*
80 #####*############*
70 ###################
60 ###################
50 ###################
40 ###################
30 ###################
20 ###################
10 ###################
    1111111 1111 1999 912   11    111111 917912  2  111   1 11 2    1111 11
    110211580491889999970696128768141433695190476468048897395570899940966407
100               *** *                  *  *
90               *** *                  *  *
80               *** *                  *  *
70               *** *                  * **
60               *** *                  * **
50               *** *                  * **
40               *** *                  * **
30               *** *                  * **
20       *   *  **** #**                **** *  *    *     ** *      **
10 **************##**#*********************#*******************************
   0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
Now, that looks interesting, I have no idea why that is happening.
#sh proc cpu sorted
CPU utilization for five seconds: 99%/86%; one minute: 90%; five minutes: 69%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
191      111604   1456919         76 13.39%  7.93%  4.38%   0 IP NAT Ager
  78       31932     20011       1595  0.16%  0.25%  0.96%   2 SSH Process
  39       45656     41723       1094  0.08%  0.02%  0.00%   0 Logger
  25      289496   3644350         79  0.08%  0.02%  0.00%   0 ARP Input
  67     3299712    416575       7921  0.08%  1.98%  1.30%   0 IP Input
  26         348    220233          1  0.08%  0.00%  0.00%   0 HC Counter Timer
   6        6476       720       8994  0.00%  0.00%  0.00%   0 Pool Manager
   8          20      9876          2  0.00%  0.00%  0.00%   0 Serial Backgroun
Looks like NAT is using a lot of CPU usage, but still does not add up to 100%. Any Ideas?
So I added some shorter timeouts to nat, but I am still seeing extremely high CPU usage.
#sh proc cpu sorted
CPU utilization for five seconds: 97%/96%; one minute: 98%; five minutes: 97%
   5      503596     76507       6582  0.49%  0.07%  0.06%   0 Check heaps
  39       63552     44058       1442  0.08%  0.02%  0.00%   0 Logger
  29       51456     76980        668  0.08%  0.03%  0.01%   0 EEM ED Syslog
105        6092   1034109          5  0.08%  0.00%  0.00%   0 CEF process
  41       23288    748560         31  0.08%  0.03%  0.02%   0 Per-Second Jobs
   2       30880    149949        205  0.00%  0.01%  0.00%   0 Load Meter
   6        6476       727       8907  0.00%  0.00%  0.00%   0 Pool Manager
   4           0         1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   9           0         2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
   3           0         1          0  0.00%  0.00%  0.00%   0 chkpt message ha
   1          28       248        112  0.00%  0.00%  0.00%   0 Chunk Manager
  12           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
   7           0         2          0  0.00%  0.00%  0.00%   0 Timers
   8          40      9918          4  0.00%  0.00%  0.00%   0 Serial Backgroun
  10           0         2          0  0.00%  0.00%  0.00%   0 ATM AutoVC Perio
  16           0         1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  17        8396    746977         11  0.00%  0.00%  0.00%   0 EnvMon
  18           0         1          0  0.00%  0.00%  0.00%   0 OIR Handler
  19           4     12515          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  11           0         2          0  0.00%  0.00%  0.00%   0 ATM VC Auto Crea
  13           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
