Router Not Working Properly
So about an hour ago, our Linksys E1500 was reset (because of my stupid attempt to reset the login and change our security type), and now I couldn't get it back to normal. I'm currently working off the ethernet connection (Old school, since our modem is still working really well and nromally).
Since I lost our Cisco Connect Set-up CD, I used the Manual Set-up Thing and all, and now it's still not working. I mean, the Router Name and Security I set are still there, but I just can't seem to get anything to load, with "Webpage Not Available" being the only thing that pops up whenever I try to load anything. I'm positive there isn't anything sure with our provider, so here are the settings I provided, please help!
Configuration View
Manual  Wi-Fi Protected Setup™
2.4 GHz Wireless Settings
Network Mode:
Network Name (SSID):
Channel Width:
Channel:
SSID Broadcast:
Enabled  Disabled
Also, the security is set to WPA2-Personal, and I changed nothing in the Basic Setup thing (The main page you get to)
Please help, and I'm sorry if this isn't the right thread to post into. Thank you!
0 Replies 0
