10-20-2010 09:50 AM - edited 03-04-2019 10:11 AM
All,
Is there a limitation on how many routers can participate in the same HSRP group?
Thanks.
Solved! Go to Solution.
10-20-2010 09:57 AM
yuhuiyao wrote:
All,
Thanks.
There is not specific limit as such. The most i have used is 4 but you can go higher than that if you want.
Note with more than 2 routers - one will be active, one standby and the others in listen state.
Jon
10-20-2010 09:57 AM
yuhuiyao wrote:
All,
Thanks.
Jon
