09-25-2020 09:14 AM
Working with Packet Tracer 7.3 trying to get a handle on a router on a stick but running into some troubles. I have created a network of 7 VLANS, 3 connected to a Layer2 2960 switch with 253,254 as a management VLAN, the last 2 are connected to another LAYER2 2960 switch with the 2 management VLANS. Those are connected to a LAYER3. Then the LAYER3 is connected to the router. Refer to the picture.
I wanted to run fiber connections for everything and ran into problems so i went back to copper, but cant run etherchannel between the layer2 switches, since there isn't enough gigabit connections. So i have the LAYER2 and LAYER3 connected with 1 copper between them with a SFP connector in the LAYER3 for the incoming.
| R1 (g0/1) | ||||
| SWM(g1/1/1) | ||||
| ↓ | ← | SWM(g1/1/2) | ||
| ↓ | SWM(g1/1/3) | → | ↓ | |
| SW1(g0/1) | SW2(g0/1) | |||
| SW1(g0/2) | ←→ | ←→ | ←→ | SW2(g0/2) |
Below is the configs for alll the switches and routers.
R1
! version 15.1 no service timestamps log datetime msec no service timestamps debug datetime msec service password-encryption ! hostname RTM ! ! ! enable secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! no ip cef no ipv6 cef ! ! ! username chris secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ! license udi pid CISCO2911/K9 sn FTX1524T40F- ! ip ssh version 2 ip domain-name chris.doyle ! spanning-tree mode pvst ! interface GigabitEthernet0/0 ip address 193.168.1.1 255.255.255.0 duplex auto speed auto ! interface GigabitEthernet0/0.10 encapsulation dot1Q 10 ip address 192.168.10.1 255.255.255.0 ! interface GigabitEthernet0/0.20 encapsulation dot1Q 20 ip address 192.168.20.1 255.255.255.0 ! interface GigabitEthernet0/0.30 encapsulation dot1Q 30 ip address 192.168.30.1 255.255.255.0 ! interface GigabitEthernet0/0.40 encapsulation dot1Q 40 ip address 192.168.40.1 255.255.255.0 ! interface GigabitEthernet0/0.50 encapsulation dot1Q 50 ip address 192.168.50.1 255.255.255.0 ! interface GigabitEthernet0/0.253 encapsulation dot1Q 253 ip address 192.168.253.1 255.255.255.0 ! interface GigabitEthernet0/0.254 encapsulation dot1Q 254 native ip address 192.168.254.1 255.255.255.0 ! interface GigabitEthernet0/1 no ip address duplex auto speed auto ! interface GigabitEthernet0/2 no ip address duplex auto speed auto shutdown ! interface GigabitEthernet0/0/0 no ip address shutdown ! interface GigabitEthernet0/1/0 no ip address shutdown ! interface Serial0/2/0 no ip address clock rate 2000000 shutdown ! interface Serial0/2/1 no ip address clock rate 2000000 shutdown ! interface Serial0/3/0 no ip address clock rate 2000000 shutdown ! interface Serial0/3/1 no ip address clock rate 2000000 shutdown ! interface Vlan1 no ip address shutdown ! ip classless ! ip flow-export version 9 ! no cdp run ! line con 0 exec-timeout 2 0 password 7 0822445C000A login ! line aux 0 ! line vty 0 4 exec-timeout 2 0 password 7 0822445C000A login local line vty 5 15 exec-timeout 2 0 password 7 0822445C000A login local ! ! ! end
SWM
! version 16.3.2 no service timestamps log datetime msec no service timestamps debug datetime msec service password-encryption ! hostname SWM ! ! enable secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ip cef no ipv6 cef ! username chris secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ip ssh version 2 no ip domain-lookup ip domain-name chris.doyle ! ! spanning-tree mode pvst ! interface GigabitEthernet1/0/1 ! interface GigabitEthernet1/0/2 ! interface GigabitEthernet1/0/3 ! interface GigabitEthernet1/0/4 ! interface GigabitEthernet1/0/5 ! interface GigabitEthernet1/0/6 ! interface GigabitEthernet1/0/7 ! interface GigabitEthernet1/0/8 ! interface GigabitEthernet1/0/9 ! interface GigabitEthernet1/0/10 ! interface GigabitEthernet1/0/11 ! interface GigabitEthernet1/0/12 ! interface GigabitEthernet1/0/13 ! interface GigabitEthernet1/0/14 ! interface GigabitEthernet1/0/15 ! interface GigabitEthernet1/0/16 ! interface GigabitEthernet1/0/17 ! interface GigabitEthernet1/0/18 ! interface GigabitEthernet1/0/19 ! interface GigabitEthernet1/0/20 ! interface GigabitEthernet1/0/21 ! interface GigabitEthernet1/0/22 ! interface GigabitEthernet1/0/23 ! interface GigabitEthernet1/0/24 switchport access vlan 254 ! interface GigabitEthernet1/1/1 ! interface GigabitEthernet1/1/2 switchport trunk native vlan 254 switchport trunk allowed vlan 10,20,30,40,50,253-254 switchport trunk encapsulation dot1q switchport mode trunk ! interface GigabitEthernet1/1/3 switchport trunk native vlan 254 switchport trunk allowed vlan 10,20,30,40,50,253-254 switchport trunk encapsulation dot1q switchport mode trunk ! interface GigabitEthernet1/1/4 ! interface Vlan1 no ip address shutdown ! interface Vlan10 description Sales VLAN10 (192.168.10.0) mac-address 0002.4a01.4901 ip address 192.168.10.2 255.255.255.0 ip helper-address 192.168.10.1 ! interface Vlan20 description Purchasing VLAN20 (192.168.20.0) mac-address 0002.4a01.4902 ip address 192.168.20.2 255.255.255.0 ip helper-address 192.168.20.1 ! interface Vlan30 description Security VLAN30 (192.168.30.0) mac-address 0002.4a01.4903 ip address 192.168.30.2 255.255.255.0 ip helper-address 192.168.30.1 ! interface Vlan40 description Engineering VLAN40 (192.168.40.0) mac-address 0002.4a01.4904 ip address 192.168.40.2 255.255.255.0 ip helper-address 192.168.40.1 ! interface Vlan50 description Quality VLAN50 (192.168.50.0) mac-address 0002.4a01.4905 ip address 192.168.50.2 255.255.255.0 ip helper-address 192.168.50.1 ! interface Vlan253 description Management VLAN253 (192.168.253.0) mac-address 0002.4a01.4906 ip address 192.168.253.2 255.255.255.0 ip helper-address 192.168.253.1 ! interface Vlan254 description Management VLAN254 (192.168.254.0) mac-address 0002.4a01.4907 ip address 192.168.254.2 255.255.255.0 ip helper-address 192.168.254.1 ! ip default-gateway 192.168.1.1 ip classless ! ip flow-export version 9 ! banner motd Authorized Users Only! ! line con 0 exec-timeout 2 0 password 7 0822445C000A login ! line aux 0 ! line vty 0 4 exec-timeout 2 0 password 7 0822445C000A login local transport input ssh line vty 5 15 exec-timeout 2 0 password 7 0822445C000A login local transport input ssh ! end
SW1
! version 12.2 no service timestamps log datetime msec no service timestamps debug datetime msec service password-encryption ! hostname SW1 ! enable secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ! ! ip ssh version 2 no ip domain-lookup ip domain-name chris.doyle ! username chris secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ! ! spanning-tree mode pvst spanning-tree extend system-id ! interface FastEthernet0/1 switchport access vlan 10 switchport mode access ! interface FastEthernet0/2 switchport access vlan 10 switchport mode access ! interface FastEthernet0/3 switchport access vlan 10 switchport mode access ! interface FastEthernet0/4 switchport access vlan 10 switchport mode access ! interface FastEthernet0/5 switchport access vlan 10 switchport mode access ! interface FastEthernet0/6 switchport access vlan 10 switchport mode access ! interface FastEthernet0/7 switchport access vlan 10 switchport mode access ! interface FastEthernet0/8 switchport access vlan 10 switchport mode access ! interface FastEthernet0/9 switchport access vlan 20 switchport mode access ! interface FastEthernet0/10 switchport access vlan 20 switchport mode access ! interface FastEthernet0/11 switchport access vlan 20 switchport mode access ! interface FastEthernet0/12 switchport access vlan 20 switchport mode access ! interface FastEthernet0/13 switchport access vlan 20 switchport mode access ! interface FastEthernet0/14 switchport access vlan 20 switchport mode access ! interface FastEthernet0/15 switchport access vlan 20 switchport mode access ! interface FastEthernet0/16 switchport access vlan 20 switchport mode access ! interface FastEthernet0/17 switchport access vlan 30 switchport mode access ! interface FastEthernet0/18 switchport access vlan 30 switchport mode access ! interface FastEthernet0/19 switchport access vlan 30 switchport mode access ! interface FastEthernet0/20 switchport access vlan 30 switchport mode access ! interface FastEthernet0/21 switchport access vlan 30 switchport mode access ! interface FastEthernet0/22 switchport access vlan 30 switchport mode access ! interface FastEthernet0/23 switchport access vlan 30 switchport mode access ! interface FastEthernet0/24 switchport access vlan 254 ! interface GigabitEthernet0/1 switchport trunk native vlan 254 switchport trunk allowed vlan 10,20,30,40,50,253-254 switchport mode trunk ! interface GigabitEthernet0/2 switchport trunk native vlan 254 switchport trunk allowed vlan 10,20,30,40,50,253-254 switchport mode trunk ! interface Vlan1 no ip address shutdown ! interface Vlan10 description Sales VLAN10 (192.168.10.0) mac-address 00e0.f92c.2501 ip address 192.168.10.3 255.255.255.0 ip helper-address 192.168.10.1 ! interface Vlan20 description Purchasing VLAN20 (192.168.20.0) mac-address 00e0.f92c.2502 ip address 192.168.20.3 255.255.255.0 ip helper-address 192.168.20.1 ! interface Vlan30 description Security VLAN30 (192.168.30.0) mac-address 00e0.f92c.2503 ip address 192.168.30.3 255.255.255.0 ip helper-address 192.168.30.1 ! interface Vlan40 description Engineering VLAN40 (192.168.40.0) mac-address 00e0.f92c.2504 ip address 192.168.40.3 255.255.255.0 ip helper-address 192.168.40.1 ! interface Vlan50 description Quality VLAN50 (192.168.50.0) mac-address 00e0.f92c.2505 ip address 192.168.50.3 255.255.255.0 ip helper-address 192.168.50.1 ! interface Vlan253 description Management VLAN253 (192.168.253.0) mac-address 00e0.f92c.2506 ip address 192.168.253.3 255.255.255.0 ip helper-address 192.168.253.1 ! interface Vlan254 description Management VLAN254 (192.168.254.0) mac-address 00e0.f92c.2507 ip address 192.168.254.3 255.255.255.0 ip helper-address 192.168.254.1 ! ip default-gateway 192.168.1.1 ! banner motd Authorized Users Only! ! ! ! line con 0 password 7 0822445C000A login exec-timeout 2 0 ! line vty 0 4 exec-timeout 2 0 password 7 0822445C000A login local transport input ssh line vty 5 15 exec-timeout 2 0 password 7 0822445C000A login local transport input ssh ! ! ! ! end
SW2
! version 12.2 no service timestamps log datetime msec no service timestamps debug datetime msec service password-encryption ! hostname SW2 ! enable secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ! ! ip ssh version 2 no ip domain-lookup ip domain-name chris.doyle ! username chris secret 5 $1$mERr$H0oY13XBA7VgU8Jsh9kWY0 ! ! ! spanning-tree mode pvst spanning-tree extend system-id ! interface FastEthernet0/1 switchport access vlan 40 switchport mode access ! interface FastEthernet0/2 switchport access vlan 40 switchport mode access ! interface FastEthernet0/3 switchport access vlan 40 switchport mode access ! interface FastEthernet0/4 switchport access vlan 40 switchport mode access ! interface FastEthernet0/5 switchport access vlan 40 switchport mode access ! interface FastEthernet0/6 switchport access vlan 40 switchport mode access ! interface FastEthernet0/7 switchport access vlan 40 switchport mode access ! interface FastEthernet0/8 switchport access vlan 40 switchport mode access ! interface FastEthernet0/9 switchport access vlan 40 switchport mode access ! interface FastEthernet0/10 switchport access vlan 40 switchport mode access ! interface FastEthernet0/11 switchport access vlan 40 switchport mode access ! interface FastEthernet0/12 switchport access vlan 40 switchport mode access ! interface FastEthernet0/13 switchport access vlan 50 switchport mode access ! interface FastEthernet0/14 switchport access vlan 50 switchport mode access ! interface FastEthernet0/15 switchport access vlan 50 switchport mode access ! interface FastEthernet0/16 switchport access vlan 50 switchport mode access ! interface FastEthernet0/17 switchport access vlan 50 switchport mode access ! interface FastEthernet0/18 switchport access vlan 50 switchport mode access ! interface FastEthernet0/19 switchport access vlan 50 switchport mode access ! interface FastEthernet0/20 switchport access vlan 50 switchport mode access ! interface FastEthernet0/21 switchport access vlan 50 switchport mode access ! interface FastEthernet0/22 switchport access vlan 50 switchport mode access ! interface FastEthernet0/23 switchport access vlan 50 switchport mode access ! interface FastEthernet0/24 switchport access vlan 254 ! interface GigabitEthernet0/1 switchport trunk native vlan 254 switchport trunk allowed vlan 10,20,30,40,50,253-254 switchport mode trunk ! interface GigabitEthernet0/2 switchport trunk native vlan 254 switchport trunk allowed vlan 10,20,30,40,50,253-254 switchport mode trunk ! interface Vlan1 no ip address shutdown ! interface Vlan10 description Sales VLAN10 (192.168.10.0) mac-address 00e0.a3d2.1301 ip address 192.168.10.4 255.255.255.0 ip helper-address 192.168.10.1 ! interface Vlan20 description Purchasing VLAN20 (192.168.20.0) mac-address 00e0.a3d2.1302 ip address 192.168.20.4 255.255.255.0 ip helper-address 192.168.20.1 ! interface Vlan30 description Security VLAN30 (192.168.30.0) mac-address 00e0.a3d2.1303 ip address 192.168.30.4 255.255.255.0 ip helper-address 192.168.30.1 ! interface Vlan40 description Engineering VLAN40 (192.168.40.0) mac-address 00e0.a3d2.1304 ip address 192.168.40.4 255.255.255.0 ip helper-address 192.168.40.1 ! interface Vlan50 description Quality VLAN50 (192.168.50.0) mac-address 00e0.a3d2.1305 ip address 192.168.50.4 255.255.255.0 ip helper-address 192.168.50.1 ! interface Vlan253 description Management VLAN253 (192.168.253.0) mac-address 00e0.a3d2.1306 ip address 192.168.253.4 255.255.255.0 ip helper-address 192.168.253.1 ! interface Vlan254 description Management VLAN254 (192.168.254.0) mac-address 00e0.a3d2.1307 ip address 192.168.254.4 255.255.255.0 ip helper-address 192.168.254.1 ! ip default-gateway 192.168.1.1 ! banner motd Authorized Users Only! ! ! ! line con 0 password 7 0822445C000A login exec-timeout 2 0 ! line vty 0 4 exec-timeout 2 0 password 7 0822445C000A login local transport input ssh line vty 5 15 exec-timeout 2 0 password 7 0822445C000A login local transport input ssh ! ! ! ! end
Any comments will be greatly appreciated.
09-25-2020 09:28 AM
Hello @ChristopherDoyle ,
a) first of all, the L2 switches should have only one SVI interface VLAN configured and active for their management otherwise you have 3 L3 switches.
b) you need to connect all the switches between them with a trunk link carrying all Vlans you don't need etherchannel at least not for a simple lab
C) on the router you cannot have at the same time an IP address on the physical interface gi0/0 and
enc dot1q native for gi0/0.254 this is not allowed. I think this is the root cause of your issues.
To what interface belong received untagged frames gi0/0 or gi0/0.254 ?
I would suggest you to move the L3 configuration under gi0/ 0 main interface under a subinterface with the correct encapsulation .
The ip default gaeway of L2 switch have to be in the management subnet.
Hope to help
Giuseppe
09-25-2020 09:31 AM
Christopher,
What is the actual issue you are having?
09-25-2020 09:55 AM
I have one pc on SW1 cant ping a computer on SW2
I would suggest you to move the L3 configuration under gi0/ 0 main interface under a subinterface with the correct encapsulation .t ping a computer on SW2.
I dont understand that.
09-25-2020 10:27 AM
Can't ping from R1 on down, can't ping from SWM to PC's or R1
1. got rid of the 192.168.1.1 on g0/0 on R1
2. removed the extra VLAN254 on the f0/24 on the L2 Switchs and in the L3 on g0/24
09-25-2020 01:30 PM
post your zipped Packet Tracer project (.pkt) file.
09-26-2020 12:36 PM
You can attach your PT file here but it must be in a ZIP format
09-28-2020 07:36 AM
