router on a stick using IE 4000 and IE 5000 switch
kamal el assaad
hello,
i tried to configure router on a stick using :
PC A: 10.12.178.5  Vlan 178
PC B : 10.12.177.5  Vlan 177
IE 4000 as access switch and IE 5000 as a routing switch.
the configuration in IE 4000 was:
vlan 177
name student
exit
vlan 178
name college
exit
int gi1/2
switchport mode access
switchport access vlan 177
exit
int gi1/3
switchport access vlan 178
exit
int gi1/4
switchport mode trunk
switchport trunk allowed vlan 177,178
exit
For IE 5000 the config was:
vlan 177
name student
exit
vlan 178
name college
exit
int vlan 177
ip address 10.12.177.1 255.255.255.0
no shutdown
exit
int vlan 178
ip address 10.12.178.1 255.255.255.0
no shutdown
exit
int gi1/8
exit
ip routing
exit
after using this configuration, i was not able to ping from A to B . any idea to resolve the problem please??
thank you in advance
Any switch will run spanning tree on its access ports. So both the 4000 and the 5000 would be running spanning tree. It does not need to show up in the running config to run spanning tree. What would show up in the running config is if you wanted to change some of the default properties of spanning tree (if you wanted one of the enhancements to standard spanning tree such as Rapid spanning tree, or if you wanted a feature like portfast or bpduguard).
Rick
12 Replies 12
Richard Burts
Is it possible that one or both of the PCs have a firewall or other security policies running that do not permit ping?
Can the PC in vlan 177 ping its gateway address on the 5000? Can the PC in vlan 177 ping the gateway address for vlan 178 on the 5000?
Can you do show arp on the 5000 and post the output?
Rick
hello
i can't ping the gateway of each IPs.
the arp result for IE5000 is:
Protocol Address Age (min) Hardware Addr Type Interface
Internet 10.11.123.248 - 2cd0.2d5e.8041 ARPA Vlan43
Internet 10.12.177.1 - 2cd0.2d5e.8042 ARPA Vlan177
Internet 10.12.178.1 - 2cd0.2d5e.8043 ARPA Vlan178
ti arp result of IE4000 is:
Internet 10.11.123.1 0 Incomplete ARPA
Internet 10.11.123.166 - 00b1.e374.12c1 ARPA Vlan43
Hello
IE 5000 is the L3 switch and IE4000 is an access switch however on the IE4000 you show:
Can you confirm the trunk berween these two switches is created and is an active state,
Can you ping the SVI's interfaces vlan 177-178 from the IE5000, whats the status of those interfaces?
Lasty wheres the location of the L3 routed interface for vlan 43?
sh interface trunks
sh interface vlan 177 & 178
Kind Regards
Paul
hello
yeah IE5000 is the layer 3 switch and IE4000 is the access switch
vlan 43 was already configured before but its not requested on my task
the sh interface trunk results for IE5000 and IE4000 are consecutively :
IE5000
Port Mode Encapsulation Status Native vlan
Gi1/8 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi1/8 1-4094
Port Vlans allowed and active in management domain
Gi1/8 1,16,32,43,48,64,80,96,112,128,177-178,240,999
Port Vlans in spanning tree forwarding state and not pruned
IE4000
Gi1/4 on 802.1q trunking 1
Gi1/4 177-178
Gi1/4 177-178
Gi1/4 none
the show interface result for 177 and 178 are:
vlan 177
Vlan177 is up, line protocol is up
*Jan 2 00:00:42.796: %LINK-
Hardware is EtherSVI, address is 2cd0.2d5e.8042 (bia 2cd0.2d5e.8042)
ate to a
Internet address is 10.12.177.1/24
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,d st
reliability 255/255, txload 1/255, rxload 1/255vely down
*Jan 2 00:00:
Encapsulation ARPA, loopback not setbitEthernet1/1
Keepalive not suppo
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
1 packets output, 64 bytes, 0 underruns
0 output errors, 1 interface resets
0 unknown protocol drops
vlan 178
Vlan178 is up, line protocol is up
Hardware is EtherSVI, address is 2cd0.2d5e.8043 (bia 2cd0.2d5e.8043)
Internet address is 10.12.178.1/24
Keepalive not supported
Last input never, output 00:27:08, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
Thank you for the additional information. I believe that it is significant that you are not able to ping the gateway of each IP. Am I correct in understanding that the 2 switches are connected to each other using vlan 43 and that the 4000 has interface vlan 43 for management access to that switch? And that vlan 43 is the only vlan interface on the 4000? Perhaps the output of show ip interface brief from both switches would help us understand this better.
I am puzzled how that is working and suspect that there are parts of the configuration that we have not seen that are significant to this issue.The trunk that you showed on the 4000 allows only vlans 177 and 178. So where is the connection for vlan 43? Perhaps this explain why each switch has an arp entry for its own address in vlan 43 but does not have an entry for the peer switch on vlan 43.
Perhaps the output of show cdp neighbor from both switches would shed some light on how they are connected. I would also like to see the output of show interface status and of show interface trunk from both switches.
Rick
hello
kindly find the following results:
for IE 4000
Vlan1 unassigned YES NVRAM administratively down down
Vlan43 10.11.123.166 YES NVRAM up down
GigabitEthernet1/1 unassigned YES unset down down
GigabitEthernet1/2 unassigned YES unset up up
GigabitEthernet1/3 unassigned YES unset up up
GigabitEthernet1/4 unassigned YES unset up up
GigabitEthernet1/5 unassigned YES unset administratively down down
GigabitEthernet1/6 unassigned YES unset administratively down down
GigabitEthernet1/7 unassigned YES unset administratively down down
GigabitEthernet1/8 unassigned YES unset administratively down down
GigabitEthernet1/9 unassigned YES unset administratively down down
GigabitEthernet1/10 unassigned YES unset administratively down down
GigabitEthernet1/11 unassigned YES unset down down
GigabitEthernet1/12 unassigned YES unset down down
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID Local Intrfce Holdtme Capability Platform Port ID
Total cdp entries displayed : 0
Port Name Status Vlan Duplex Speed Type
Gi1/1 notconnect trunk auto auto Not Present
Gi1/2 connected 177 a-full a-100 10/100/1000Ba
seTX
Gi1/3 connected 178 a-full a-1000 10/100/1000Ba
seTX
Gi1/4 connected trunk a-full a-1000 10/100/1000Ba
seTX
Gi1/5 disabled 1 auto auto Not Present
Gi1/6 disabled 1 auto auto Not Present
Gi1/7 disabled 1 auto auto Not Present
Gi1/8 disabled 1 auto auto Not Present
Gi1/9 disabled 1 auto auto Not Present
Gi1/10 disabled 1 auto auto Not Present
Gi1/11 notconnect trunk auto auto Not Present
Gi1/12 notconnect trunk auto auto Not Present
Gi1/4 177-178
Gi1/4 177-178
Gi1/4 none
hello
kindly find the results of IE5000
Vlan43 10.11.123.248 YES NVRAM up up
Vlan177 10.12.177.1 YES manual up up
Vlan178 10.12.178.1 YES manual up up
GigabitEthernet1/1 unassigned YES unset administratively down down
GigabitEthernet1/2 unassigned YES unset administratively down down
GigabitEthernet1/3 unassigned YES unset administratively down down
GigabitEthernet1/4 unassigned YES unset administratively down down
GigabitEthernet1/8 unassigned YES unset up up
GigabitEthernet1/11 unassigned YES unset administratively down down
GigabitEthernet1/12 unassigned YES unset administratively down down
GigabitEthernet1/13 unassigned YES unset do
GigabitEthernet1/14 unassigned YES unset administratively down down
GigabitEthernet1/15 unassigned YES unset administratively down down
GigabitEthernet1/16 unassigned YES unset administratively down down
GigabitEthernet1/17 unassigned YES unset administratively down down
GigabitEthernet1/18 unassigned YES unset administratively down down
GigabitEthernet1/19 unassigned YES unset administratively down down
GigabitEthernet1/20 unassigned YES unset administratively down down
GigabitEthernet1/21 unassigned YES unset administratively down down
GigabitEthernet1/22 unassigned YES unset administratively down down
GigabitEthernet1/23 unassigned YES unset administratively down down
GigabitEthernet1/24 unassigned YES unset down down
TenGigabitEthernet1/25 unassigned YES unset down down
TenGigabitEthernet1/26 unassigned YES unset down down
TenGigabitEthernet1/27 unassigned YES unset administratively down down
TenGigabitEthernet1/28 unassigned YES unset administratively down down
Gi1/8 1-4094
Gi1/1 disabled 1
seTX
Gi1/2 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/3 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/4 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/5 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/6 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/7 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/8 connected trunk a-full a-1000 10/100/1000Ba
seTX
Gi1/9 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/10 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/11 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/12 disabled 1 auto auto 10/100/1000Ba
seTX
Gi1/13 notconnect trunk auto auto Not Present
Gi1/14 disabled 1 auto auto Not Present
Gi1/15 disabled 1 auto auto Not Present
Gi1/16 disabled 1 auto auto Not Present
Gi1/17 disabled 1 auto auto Not Present
Gi1/18 disabled 1 auto auto Not Present
Gi1/19 disabled 1 auto auto Not Present
Gi1/20 disabled 1 auto auto Not Present
Gi1/21 disabled 1 auto auto Not Present
Gi1/22 disabled 1 auto auto Not Present
Gi1/23 disabled 1 auto auto Not Present
Gi1/24 notconnect trunk auto auto Not Present
Te1/25 notconnect trunk full 10G Not Present
Te1/26 notconnect trunk full 10G Not Present
Te1/27 disabled 1 full 10G Not Present
Te1/28 disabled 1 full 10G Not Present
so if i remove vlan 43, i will ping successfully?
Actually vlan 43 does not really have anything to do with whether vlans 177 and 178 will work. If vlan 43 is not needed you might as well remove it. But there are other problems that are impacting vlans 177 and 178.
My first observation is that the show cdp neighbor from both switches indicates that neither switch sees any neighbor.
My second observation is this output from show interface trunk from the 4000
Gi1/4 none
There are no vlans carried on this trunk for the 4000. That would explain why the switches are not seeing each other. Nothing is carried over the trunk. So why is that? Perhaps the output of show vlan and of show spanning status might shed some light on this. It might also be helpful if you would post the complete config of the 4000.
Rick
IE4000 is as an access switch so the devices connected directly hold the vlan number 177 and 178.
in the other hand IE5000 is a switch with routing feature so it include all the vlans of the network.
regarding the spanning-tree, is it affect to block the ping between 4000 and 5000? if is it not configured in the 4000 switch?
Rick
I am glad that my explanation was helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
