Router or Firewall
wrwiii122
When an ISP issues a low grade box it is a router and a firewall. I am looking to take a box like this and put in a 3550. My question is can a 3550 do PPPOE, port forwarding, and Natting. Or would I have to put a PIX in line to do all of this?
bbaley
Level 3
Level 3
If NAT is not enabled, you do not have to do port forwarding . PPPoE connection can be made to the ISP with PAP/(MS)CHAP authentication. The supported features are Forwarding Control, DMZ Support, Firewall Rules Database, Port Triggering
So I could use a 3550 to do what the router/firewall does?
