Router password issue
rashev_kamen
This is going to be probably very stupid question to you guys but I'm a new in the cisco routing. We got 2821 router and configured it. It was with default passwords 'cisco' , 'cisco'. I used #enable secret XXXXXX to change password and now when I try to telnet it's asking me for username and password. What suppose to be the username? Am I gonna be asked for username if I use console connection?
lamav
Level 8
Level 8
Rashey, your question is not stupid at all.
If you have a router configured with a username and password and the login local command configured under line vty 0 4, you will be prompted for the username and password when you telnet to the router.
Example:
username MY ROUTER password MYPASSWORD
line vty 0 4
login local
You will also get prompted for a username and password if you're configured for TACACS, but that's another story. :-)
Try going in through the console.
If so, please rate this post.
Victor
Edison Ortiz
If you enable aaa new-model it will affect all incoming connections to the router and if you forgot to enter an username & password in the configuration, your only choice is rebooting the router.
Hopefully, you didn't save the config after making those changes, if you did, you will have to perform a password recovery.
Let's us know what kind of configuration was entered in addition to "enable secret". That command by itself won't cause the username prompt.
HTH,
__
Edison.
