Router: port forwarding problems.
PMOvchinnikov
I want to make my HTTP-server accessible from the outside (it's located on my LAN).
HTTP-server listens on port TCP 80 on all interfaces, IP address 192.168.112.17/24. (I can ping outside addresses from this machine.) My router - Cisco 2951, here's a part of its config:
interface GigabitEthernet0/0
ip address W.A.N.IPAddress W.A.N.Netmask
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 192.168.112.254 255.255.255.0
ip nat inside
duplex auto
speed auto
ip forward-protocol nd
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.112.17 80 W.A.N.IPAddress 80 extendable
ip route 0.0.0.0 0.0.0.0 W.A.N.GatewayIP
access-list 1 permit 192.168.X.0 0.0.0.255
access-list 1 permit 192.168.112.0 0.0.0.255
access-list 1 permit 192.168.Z.0 0.0.0.255
access-list 101 permit tcp any host W.A.N.IPAddress eq www
So I cannot reach the server from the outside. The router responds to pings (ICMP echo packets). I'm entering router's W.A.N.IPAddress in my browser's address field and there's no result. Help me, please!
Here is simple config:
ip nat inside source static tcp 192.168.112.17 80 46.45.33.X 80
As WAN IP address for server here you need to use one spare address from your scope e.g. 46.45.33.5 as you have big enough subnet /25.
Also I would not recommend to post here real Public IP addresses.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093f31.shtml
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
8 Replies 8
cadet alain
the easiest way to get this working ( access WAN public IP of server from inside) is to replace your NAT configuration like this:
int g0/0
no ip nat out
no icmp redirect
ip nat enable
int g0/1
no ip nat in
no icmp redirect
ip nat enable
no ip nat inside source list 1 int g0/0
ip nat source list 1 int g0/0
no ip nat inside source static tcp 192.168.112.17 80 x.x.x.x 80
ip nat source static tcp 192.168.112.17 80 x.x.x.x 80
Regards.
Alain
Thank you, Cadet Alain.
One more question: I have two subinterfaces on the router's inside interface (GigabitEthernet0/1) configured this way:
interface GigabitEthernet0/1.X
encapsulation dot1Q X
ip address 192.168.X.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.Z
encapsulation dot1Q Z
ip address 192.168.Z.254 255.255.255.0
ip nat inside
How to configure them using your method?
to use NVI just replace ip nat inside and ip nat outside by ip nat enable
Regards.
Alain
First attempt failed. Using "old school method" to perform NAT (NAT Inside/Outside) networks connected via GigabitEthernet0/1 interface (and subinterfaces) are automatically routed. (Command "show ip route" lists networks connected to the router and there's no need to configure routes.)
Using your method to perform NAT enables NVI interface (NVI0) on the router. I rolled back to the previous configuration and mention that: NVI0 interface is up (how to shut it down?) and there is no output for command "show ip nat translations".
Maybe I should read more about using NAT and NVI.
Help me, please. Question: I have a website located on my LAN, I have a router inbetween WAN and LAN, I want make the website accessible from WAN.
Router's config:
Current configuration : 2252 bytes
version 15.2
service password-encryption
hostname edge
boot-start-marker
boot-end-marker
no aaa new-model
no ipv6 cef
ip domain name sphti.ru
ip cef
license udi pid CISCO2951/K9 sn FCZ162920ED
username privilege 15 password 7
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address 46.45.33.4 255.255.255.128
ip nat outside
duplex auto
speed auto
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.111
encapsulation dot1Q 111
ip address 192.168.111.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.113
encapsulation dot1Q 113
ip address 192.168.113.254 255.255.255.0
ip nat inside
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
no ip http server
no ip http secure-server
ip nat translation timeout 600
ip route 0.0.0.0 0.0.0.0 46.45.33.1
access-list 1 permit 192.168.111.0 0.0.0.255
access-list 1 permit 192.168.113.0 0.0.0.255
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
no login
transport input none
scheduler allocate 20000 1000
end
Web-server's network config:
IP Address: 192.168.112.17
Netmask: 255.255.255.0
DNS: 192.168.112.2
Gateway: 192.168.112.254
How finally to configure the router? Help me, please!
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
One spare address means that I should configure router's outside (WAN) interface with secondary IP address, right?
Thank you, Abzal Sembay! Everything's allright now!
