EBGP ROUTE FLAPPING
Dear all,
I have a senario where all the ibgp neighbors are stable. As soon as i peer one of the ibgp router to another router in different autonomous system, the ebgp peers begin to flap.
See error below:
*Mar  1 15:04:25.404: %BGP-3-NOTIFICATION: sent to neighbor 8.8.8.8 4/0 (hold time expired) 0 bytes
The ebgp router are directly connected via serial ports. Also, both serial ports have MTU of 1500.
Find sample config:
R6:
interface Serial0/0
ip address 10.10.68.6 255.255.255.0
clock rate 2000000
router ospf 10
log-adjacency-changes
redistribute bgp 3 subnets
network 6.6.6.6 0.0.0.0 area 0
network 10.10.56.0 0.0.0.255 area 0
network 10.10.67.0 0.0.0.255 area 0
network 10.10.68.0 0.0.0.255 area 0
router bgp 3
no synchronization
bgp log-neighbor-changes
bgp suppress-inactive
network 6.6.6.6 mask 255.255.255.255
network 10.10.56.0 mask 255.255.255.0
network 10.10.67.0 mask 255.255.255.0
redistribute ospf 10 metric 1
neighbor 3.3.3.3 remote-as 3
neighbor 3.3.3.3 update-source Loopback0
neighbor 3.3.3.3 next-hop-self
neighbor 4.4.4.4 remote-as 3
neighbor 4.4.4.4 update-source Loopback0
neighbor 4.4.4.4 next-hop-self
neighbor 5.5.5.5 remote-as 3
neighbor 5.5.5.5 update-source Loopback0
neighbor 5.5.5.5 next-hop-self
neighbor 7.7.7.7 remote-as 3
neighbor 7.7.7.7 update-source Loopback0
neighbor 7.7.7.7 next-hop-self
neighbor 8.8.8.8 remote-as 89
neighbor 8.8.8.8 ebgp-multihop 2
neighbor 8.8.8.8 update-source Loopback0
no auto-summary
R8:
interface Serial0/0
ip address 10.10.68.8 255.255.255.0
clock rate 2000000
router ospf 10
redistribute bgp 89 subnets
network 8.8.8.8 0.0.0.0 area 0
network 10.10.89.0 0.0.0.255 area 0
router bgp 89
no synchronization
network 8.8.8.8 mask 255.255.255.255
network 10.10.68.0 mask 255.255.255.0
network 10.10.89.0 mask 255.255.255.0
neighbor 6.6.6.6 remote-as 3
neighbor 6.6.6.6 ebgp-multihop 2
neighbor 6.6.6.6 update-source Loopback0
neighbor 9.9.9.9 remote-as 89
neighbor 9.9.9.9 update-source Loopback0
neighbor 9.9.9.9 next-hop-self
no auto-summary
Please, help explain how i can fix this unstable and flapping ebgp peers.
Ethelbert
Giuseppe Larosa
Hello Etherlbert,
your R8 router is advertising its own side eBGP endpoint 8.8.8.8/32 over the eBGP connection.
before the eBGP connection comes up R6 router learns of the R8 eBGP endpoint address 8.8.8.8/32 from OSPF intra area route with admin distance 110 and metric 2 (guess).
As soon as the eBGP session comes up R6 installs an eBGP route to 8.8.8.8 via 8.8.8.8 and this is the root cause of the BGP session instability. This route has AD 20 and is preferred over the OSPF route.
I would suggest to try the following:
R8
router bgp 89
no network 8.8.8.8 mask 255.255.255.255
This should solve the instabilty issue as the OSPF route will not be overriden by an eBGP route
Hope to help
Giuseppe
Praveen AR
Hello Etherlbert,
Yes Giuseppe  is correct advertising   8.8.8.8 in bgp creating flap in your EBGP.
Praveen
Thanks for the responses.
Really appreciate.
Ethelbert
