Router Port Issue
sutharhemant90
I've got a cisco 1921 in a org. where we've added an extra gi interface and as long as a network cable is connected it works fine.
However if the network cable is disconnected and then reconnected the inteface doesn't start up again until I log into the router, enter config mode for the interface and issue the "shut" and "no shut" command.
7 Replies 7
Sandeep Choudhary
HI Hement,
Please post the output of these commands:
1. Show inv
2. show diag
3. show int gi ?
4. sh run int gi ?
5. sh version
XXXX#show inventory
NAME: "CISCO1921/K9 chassis", DESCR: "CISCO1921/K9 chassis"
PID: CISCO1921/K9      , VID: V05 , SN: XXX
NAME: "Enhanced High Speed WAN Interface Card-1 Port Gigabit Ethernet SFP/Cu on Slot 0 SubSlot 0", DESCR: "Enhanced High Speed WAN Interface Card-1 Port Gigabit Ethernet SFP/Cu"
PID: EHWIC-1GE-SFP-CU  , VID: V01, SN: FOC1704704G
XXXX#show diag
Slot 0:
        C1921 Mother board 2GE, integrated VPN and 2W Port adapter, 3 ports
        Port adapter is analyzed
        Port adapter insertion time 1w6d ago
        EEPROM contents at hardware discovery:
        PCB Serial Number        : FOC16461WSL
        Hardware Revision        : 1.0
        Part Number              : 73-12850-06
        Top Assy. Part Number    : 800-33408-04
        Board Revision           : A0
        Deviation Number         : 0
        Fab Version              : 02
        Product (FRU) Number     : CISCO1921/K9
        Version Identifier       : V05
        CLEI Code                : CMMHF10ARA
        Processor type           : C8
        Chassis Serial Number    : FGL1702217Q
        Chassis MAC Address      : e02f.6d81.3900
        MAC Address block size   : 32
        Manufacturing Test Data  : 00 00 00 00 00 00 00 00
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF C1 8B 46 4F 43 31 36 34 36 31 57 53 4C 40
          0x10: 06 AC 41 01 00 82 49 32 32 06 C0 46 03 20 00 82
          0x20: 80 04 42 41 30 88 00 00 00 00 02 02 CB 8C 43 49
          0x30: 53 43 4F 31 39 32 31 2F 4B 39 89 56 30 35 20 D9
          0x40: 04 40 C1 CB C2 C6 8A 43 4D 4D 48 46 31 30 41 52
          0x50: 41 09 C8 C2 8B 46 47 4C 31 37 30 32 32 31 37 51
          0x60: C3 06 E0 2F 6D 81 39 00 43 00 20 C4 08 00 00 00
          0x70: 00 00 00 00 00 F3 00 51 40 00 8B 41 00 3C 42 00
          0x80: 00 F8 00 24 03 E8 1B 11 07 D0 1E A2 09 C4 1F A9
          0x90: 0B B8 20 0F 0F A0 20 D3 13 88 21 6A 1B 58 21 A9
          0xA0: 1F 40 21 B8 27 10 21 3E 41 00 50 42 00 00 F8 00
          0xB0: 18 02 71 1D B0 04 E2 20 08 07 53 21 02 0E A6 22
          0xC0: 60 1D 4C 22 C4 27 10 22 C4 FF FF FF FF FF FF FF
          0xD0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xE0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
          0xF0: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
        WIC Slot 0:
        1 Port Gigabit Ethernet SFP/Copper EHWIC
        PCB Serial Number        : FOC1704704G
        Part Number              : 73-13295-01
        Board Revision           : A1
        Top Assy. Part Number    : 800-34350-01
        Fab Version              : 05
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : EHWIC-1GE-SFP-CU
        Version Identifier       : V01
        CLEI Code                : CMUIAA8CAA
        Unknown Field (type 00D4): CC
        Asset Identifier         : A0
          0x00: 04 FF C1 8B 46 4F 43 31 37 30 34 37 30 34 47 40
          0x10: 06 A3 41 01 00 82 49 33 EF 01 42 41 31 C0 46 03
          0x20: 20 00 86 2E 01 88 00 00 00 00 02 05 03 00 81 00
          0x30: 00 00 00 04 00 CB 90 45 48 57 49 43 2D 31 47 45
          0x40: 2D 53 46 50 2D 43 55 89 56 30 31 00 D9 03 40 C1
          0x50: CB C6 8A 43 4D 55 49 41 41 38 43 41 41 D4 82 43
          0x60: 43 CC 82 41 30 FF FF FF FF FF FF FF FF FF FF FF
          0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Embedded Service Engine 0/0 :
  Total platform memory : 524288K bytes
  Total 2nd core memory : 0K bytes
  Start of physical address for 2nd core : 0x80000000
  Virtual address start of 2nd core memory : 0x0 - 0x0
  2nd core configured disabled
  L2 cache ways for 2nd core : 0
XXXX#show interfaces GigabitEthernet0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is EHWIC-1GE-SFP-CU, address is e02f.6d81.3903 (bia e02f.6d81.3903)
  Internet address is X.X.X.X/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive set (10 sec)
  Full Duplex, 100Mbps, media type is RJ45
  output flow-control is XON, input flow-control is XON
  Last input 00:00:02, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     1820909 packets input, 497080236 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1133112 packets output, 109246698 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
interface GigabitEthernet0/0/0
ip address X.X.X.X 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
duplex full
speed 100
end
XXXXX#show version
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 17:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
XXXX uptime is 1 week, 6 days, 14 hours, 14 minutes
System restarted at 16:38:29 IST Fri Nov 1 2013
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID FGL1702217Q
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
249840K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          XXXX
Technology Package License Information for Module:'c1900'
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
ipbase        ipbasek9      Permanent      ipbasek9
security      None          None           None
data          None          None           None
Please find the above logs.
Hi Hemant,
Please put your interface to 'no keepalive'
Leo Laohoo
Seen this with my home 881 router.
The only solution I had was to upgrade the IOS and it went fine.
sutharhemant90
Dear All,
What Exaclty i have to do with router which can resolve my issue permamently. Please suggest me with the reason.
Hemant,
R1# conf t
R1(config)# interfaces GigabitEthernet0/0/0
R1(config-if)#no keepalive
R1(config-if)#end
