Router processor down, then it came back in a different redundancy mode
enriquebs
HI all,
Here is a question about a NSE100 processor, after an event it was reseted (by itself) and
come up in a different redundancy mode, RPR.
The event heppened while configuring an ip address in the same range than another one, then the router complained about an "overlapping" error and the standby route processor was down.
Jun 30 08:30:40: %HA-6-FALLBACK: Standby coming up in fallback mode - configured mode(SSO),
fallback mode(rpr)
Jun 30 08:30:40: %HA-6-FALLBACK: System redundancy mode fallback - configured mode(SSO),
fallback mode(RPR)
Jun 30 08:30:40: %HA-6-MODE: Operating RP redundancy mode is RPR
The "sh redund" output showed the second processor as STANDBY-COLD
It was necessary type the following command in order to get the SSO redundancy mode again:
hw-module standby reload
At present the issue is solved but I wanna know why it happened.
Thanks a lot in advance.
Regads,
Kike
a-vazquez
Level 6
Level 6
You may be running into a bug here. The bug-Id is: CSCdw46954
